missing RPO code sheet......
Old Nov 30, 2012 | 01:38 AM
snarley's Avatar
Car: 1987 z28 camaro
Engine: 305cid lb9
Axle/Gears: Base Z28 drum 3:23 ]
so i am the 4th or 5th owner of my 92 Z28.. and while wanting to do research on whats in it.... it appears the sheet with all the RPO codes has been removed.... is there any way i can get another one or figure stuff out the otherway... im just wondering because im wanting to figure out if i have the G92 or G80 rear end. iv got 4 wheel discs and something i never see out my way is the rear z28 wing. all the other Zs see are basic spoilers or nothing. would i beable to obtain a RPO code sheet form any GM dealership with the serial number? or what should i do?
Old Nov 30, 2012 | 03:38 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: missing RPO code sheet......
goto any chevy dealer give em the vin, they can get you a sheet of what options were ordered on the car basically can get you a build sheet
Old Nov 30, 2012 | 06:56 AM
:bangheadondesk:
WHY are people so unwilling to JUST LOOK AT THE PARTS?
Changed your diff fluid lately? I thought not. Too busy exerting all your mental effort on "codes" instead of using it to care of your car. So while you're catching up on the overdue routine maintenance you've been neglecting, LOOK AT THE PARTS. It's such a NO-BRAINER, even someone with NO BRAIN like me, can manage it. Surely, as smart as you are, you can do it too.
Old Nov 30, 2012 | 11:35 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
You should be able to just run the the VIN through compnine...IIRC, they have information on the later cars like yours.
http://www.compnine.com
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
64Chief
Sep 12, 2015 08:05 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
