"Limited Edition" GTA?
Old Mar 18, 2013 | 12:09 PM
blakbird89's Avatar
Car: "Nina" 1988 Trans Am GTA
Engine: TPI 305 V8
Found my dream car, 1989 black on black GTA. It has everything I've been looking for but there are some things that don't make sense and I was hoping you guys might have some insight.
First of all, the guy says it's "limited edition" but from what I've been able to find, there really is no such thing. Truth?
He mentioned also that it has a digital dash, but from what I'm aware 1988 was the last model year to have this correct?
And, what is this hood? I think I've seen one on the boards here but I can't for the life of me find it again.
Attached Thumbnails "Limited Edition" GTA?-3l83f53nf5ld5e55h2d22472460cfaab01bc6.jpg
Old Mar 18, 2013 | 12:38 PM
AmorgetRS's Avatar
Re: "Limited Edition" GTA?
True
Correct
I believe that hood is known as a Daytona Twin Turbo hood.
Old Mar 18, 2013 | 12:47 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Have you looked at this car in person, verified the RPO for GTA (Y84)? The sail panel emblem is in the wrong place and not even close to the right place. The fender emblem looks off was well. When you see it in person, look at the driver's headlight PONTIAC lettering...it should be gold. The car could have been repainted and the emblems put back on wrong, but I've noticed almost every "clone" owner forgets or doesn't know about the headlight lettering which would make me suspicious immediately upon seeing it in person.
Old Mar 18, 2013 | 12:54 PM
blakbird89's Avatar
Engine: TPI 305 V8
I'm have a feeling it is a fake. I haven't seen it in person yet, and I was a bit suspicious. The way I see it, IF a limited edition GTA did exist then I couldn't see why the owner wouldn't restore it or at least keep it stock.
I don't mind if it is just a regular TA, it's still basically the same combination I've been after.
Although I'm sure this would depreciate the asking price...
So what would you guys pay for something like this then if it's just a plain 1989 Trans Am?
- newly replaced 5 speed/clutch
- aluminum flywheel
- T-tops
- digital dash (obviously swapped)
- Twin turbo hood
- missing front seats, needs carpet
Old Mar 18, 2013 | 01:02 PM
AmorgetRS's Avatar
If it has the OEM digital dash I'd actually bet it's not a 89.
Old Mar 18, 2013 | 01:04 PM
blakbird89's Avatar
Engine: TPI 305 V8
Lol, I should've thought of that. I just like '89 because it's my birth year but I guess an '88 is good too right?
Old Mar 18, 2013 | 01:14 PM
88gunmetalgta's Avatar
If he's lying about it being a GTA, imagine how much bondo and rust he's also lying about. I'd offer about $800, he can keep the hideous hood.
Old Mar 18, 2013 | 03:05 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
, but first what's the mileage on the car? how's it run and drive? What is the asking price if you don't mind saying? That hood sucks IMO, worse the the one they make like that for the Camaro's. Also what's it look like under that bra? Bet the nose is chipped and or rashed like crazy.
Old Mar 18, 2013 | 03:08 PM
blakbird89's Avatar
Engine: TPI 305 V8
That's the only pic, not sure about the mileage but the asking price is 2k. It does run apparently. Does it run well? That's tbd...
Old Mar 18, 2013 | 04:06 PM
Slater126's Avatar
We can all be thankful for that.
Old Mar 18, 2013 | 04:25 PM
ac riggs's Avatar
Car: 89 TRANS AM GTA
Engine: 350 H.O.
Axle/Gears: 373
i have my 89 trans am in the drive way im comparing with. mine is 95% original except the motor. the emblems look wrong. the wheel caps are wrong. idk about the dash mines analog. check out the suspension on it to see if it has the wise performace suspension. that should be a dead give away if it a wanna be gta. the car still looks nice besides the hood lol
Old Mar 18, 2013 | 06:42 PM
conlinj's Avatar
Well if it is not a gta, he swapped the fenders to get rid of the vents. All T/As had the fender vents. It's probably just been repainted, its rare the emblems go back where they should on "budget" repaints
Old Mar 18, 2013 | 06:53 PM
Maybe it's not even a TA? I'll agree it is rare for emblems to get back to the right spot.
Old Mar 18, 2013 | 06:58 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
But if it is "just a Firebird" then it would have have had no vents in the fenders. Funny how the top of the line GTAs got the same fenders as the base model TBI/V6 cars. lol You'd think the vents woulda come on GTAs only just for "style points", even though I prefer the non-vent look myself.
As for the sail panel bird emblems.....The correct spot is "out of place" (off center & low) so it is very common for body shops to center them up.
Old Mar 18, 2013 | 07:06 PM
SeanO23's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Posi 3.27
even if the front end is perfect on it, if hes had that bra on there for too long it will be much blacker than the rest of the paint.
Old Mar 18, 2013 | 08:33 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1) Get the VIN, it will tell you at least whether or not it is a Trans Am/GTA or a base Firebird or Formula.
2) If it does not have TPI, then it is NOT a GTA
3) The center caps are 1987 (mentioned by previous poster)
4) The Hood is Daytona (mentioned by previous poster)
5) The GTA Emblems are in the wrong place too... too high
More than likely it is a GTA that someone repainted, put the emblems in the wrong places, and put a Daytona Hood On it for some reason.
Old Mar 19, 2013 | 07:45 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Here is the help you need. Frankie has put together a great site with excellent information.
http://www.gtasourcepage.com/newauthentication.html
Hope it isn't to late...
Old Mar 26, 2013 | 10:55 AM
blakbird89's Avatar
Engine: TPI 305 V8
Now that i'm thinking about it, is there a possibility that this car could have been made late in the 1988 production run but labeled as an 89?
Posted from Thirdgen.org App for Android
Old Mar 26, 2013 | 12:18 PM
AmorgetRS's Avatar
Whatever the VIN says is what the model year was. So it is either a 88 MY or a 89 MY, a 88 MY could of been produced in 87 or 88, and a 89 in 88 or 89.
TX-SleeperC5
Feb 24, 2016 01:34 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Navy8125
Interior Parts Wanted
Sep 23, 2015 01:11 PM
okfoz
Sep 15, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
