Anyone ever seen this Limited Edition sticker on a T/A headlamp door?
Old Oct 6, 2013 | 01:52 PM
Gen X T/A's Avatar
Car: 1987 Pontiac Firebird Trans Am
Engine: LB9
Transmission: Turbo Hydra-Matic 700R4
Axle/Gears: 2.73 limited slip differential
My 1987 Trans Am has a "Limited Edition" sticker on the face of the closed passenger side headlamp door. Does anyone recognize this sticker, and if so, know it's meaning or source?
I've always considered myself somewhat of a 3rd gen geek because I was 14 in '82 at the beginning of the gen and wanted one terribly as a teenager. Due to this I followed the evolution of the cars through the '80s and managed to know the different variations, versions and editions of the F bodies, and most of the differences between them. That said, I have no clue about this limited edition sticker on my car.
My T/A otherwise appears to be bone factory stock inside and out, and all original with the exception of tires, battery, belts, etc. There are no other limited edition references on the car. The font of the text on the sticker does not match nor compliment what Pontiac otherwise used on this car or anything associated with it from the era. That leads me to believe someone other than GM placed it there for whatever reason, and it means nothing. Yet you can tell the sticker itself was designed to perfectly fit the space it occupies. It's not hand cut. So someone made some effort when producing it, therefore there are probably more out there. This is why I have not fully dismissed it's validity.
Personally I do not believe my T/A is limited edition in any way. BUT, before I peel it off the headlamp door I want to be sure. So, do any of the hard core knowledgeable originality guys know or have any ideas about it?
In the first pic that little logo looking part to the left says "L/E" inside the circle.
Attached Thumbnails Anyone ever seen this Limited Edition sticker on a T/A headlamp door?-le.jpg   Anyone ever seen this Limited Edition sticker on a T/A headlamp door?-ta10.jpg   Anyone ever seen this Limited Edition sticker on a T/A headlamp door?-ta11.jpg
Old Oct 6, 2013 | 04:22 PM
JT's Avatar
JT
Community Administrator
Re: Anyone ever seen this Limited Edition sticker on a T/A headlamp door?
That's most likely a dealership or aftermarket item. There was no "Limited Edition" 1987 Trans Am from the factory.
Sometimes dealerships dressed up cars with Special or Limited edition stickers to help with sales. Additionally, some of those items could be purchased aftermarket. You could get Special or Limited Edition stickers that would fit right inside the small indentation of the front side of the door handles.
Old Oct 6, 2013 | 05:52 PM
Gen X T/A's Avatar
Engine: LB9
That's what I thought. Even the seller who had the car for almost 20 years told me the sticker had him scratching his head.
Thanks for the reply!
Old Oct 7, 2013 | 07:08 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I think you can get those a pep boys or something. I flipped an 84 base firebird that had the same stickers on the door handles.
Old Oct 7, 2013 | 08:22 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
At Autozone
Old Oct 7, 2013 | 02:58 PM
Gen X T/A's Avatar
Engine: LB9
Yea, that sticker is DEFINITELY coming off now!
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
SG91camaro
Sep 5, 2015 10:27 PM
