(r12 conversion to R134) Does this affect originality?
Old Feb 18, 2014 | 01:07 PM
RoccoNH1's Avatar
Car: 1986 Firebird T/A 7,213 Orig Miles
Engine: 305 4bbl V8
Transmission: 700R4 auto
I have a 1986 T/A whcih needs a recharge come the spring and I want to know if moving to the R134 (which seems like it is my only choice) what does that do to the originality of the car. My car is all original.
Any info is greatly appreciated, especially if you know anyone in NH or Mass. who does r12 recharges?
Thanks,
Rocco
Old Feb 18, 2014 | 01:29 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: (r12 conversion to R134) Does this affect originality?
No need to convert or search high and low for a serviceman. If you can use a can of fix-o-flat then you can recharge your a/c system (slightly oversimplified, but not by much).
I just did a quick ebay search and found numerous cans of r12 and recharging kits.
http://www.ebay.com/bhp/r12-refrigerant
Old Feb 18, 2014 | 02:21 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
EPA certification required for r12 purchases
Old Feb 18, 2014 | 02:29 PM
Car: 1983 Z28
Only for large cans. The smaller sets like this one require no certification:
http://www.ebay.com/itm/Refrigerant-...-/321123610737
Old Feb 18, 2014 | 03:05 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
If the A/C hasn't been charged for a long time, you may want to get it cleaned or flushed and evacuated prior to putting in the R12 or R134 (also get the leak fixed, but that's an obvious one). There's no sense in wasting money by filling it with refrigerant AND non-condensable gases. It won't be that cold and probably won't last, especially if it's leaking.
Old Feb 18, 2014 | 07:47 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 was converted to r-134 by a a/c shop in NC several years back.
Except for a couple of "this system has been changed to r-134 etc etc."
warning/charging instruction stickers the system looks the exact same
as the day it left the factory.
As far as it effecting originality/resale/etc. IMO I think not !
Most folks would love driving their "classic" to the local cruise-in/show/ride
to grandmas house with the family in cool comfort on a hot steamy day!
Old Feb 18, 2014 | 09:10 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
R134 won't cool enough in the south. The condenser isn't large enough. As others have said, get the leak fixed first. It's more than likely the compressor that's leaking. It's common and usually not an inexpensive fix. If you look at the hood insulator just above the compressor, you'll probably see oil splattered all over it. The bearings are going and allowing the freon to leak out.
I don't have R12 in my car anymore, and I don't have any stickers or fittings any different from stock. You just need to inform any future buyers or service centers what's in the system as many shops won't service or evacuate the system if it's not something they can recapture without contamination. They don't like mixing the different gases in their recovery system.
Old Feb 19, 2014 | 07:01 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
SURE any r-134 conversion won't cool as low as a stock R-12 set up!
None of my factory r-134 brand new cooled as good or as cold as my other
new from the factory GM vehicles either......................
I lived in south Fla and NC so I KNOW HOT and muggy summer days!
Old Feb 19, 2014 | 07:31 PM
Not sure what difference "originality" is going to make in the long run...
So: turn the question around and ask it this way:
Which car would you rather have; one with a working A/C, or one without?
Now that you have the answer to that question, which is better: a working A/C with R-134A, or a non-working one without R-12?
I'm kinda dumb, as everyone knows; still, I'm struggling with how this question even has to be asked.
Old Feb 21, 2014 | 07:45 PM
RoccoNH1's Avatar
Engine: 305 4bbl V8
Thanks for the response. The reason I ask is because my car is 100% original and I don't know if it will affect anything. Sure maybe it is a stupid question but I think it's a valid one in my case. It's not some car that I threw together . Nothing wrong with that and if the car had 100k miles on it I really wouldn't care. But since its rare and all original, I want to keep it that way. I don't know what's involved in a conversion... I don't know what they do... So I'll do more research after it becomes nicer out. Car is still in storage tip April. :-(
Old Feb 21, 2014 | 09:01 PM
4mula5.oh's Avatar
Car: 1990 formula
Engine: 305 LO3
Transmission: auto
I have a 90 formula and the ac leaked. had it evacuated and had stop leak with the oil in it and then put r134 in it. all I had to do was screw a different fitting and that's it and it works fine. that was 10 years ago and I don't drive it a lot and I recharged it for the first time last spring. I would say if you wanted to keep it original is like keeping the same gas and oil in it. lol
Old Feb 21, 2014 | 09:09 PM
OK, let's look at it from YET ANOTHER common-sense angle:
Is your car SO ORIGINAL that in some form of originality contest, they're going to chemically analyze the contents of your A/C system?
So, are you ALSO worried that they're going to check your gas tank for the original fuel, your tires for the original air, your battery for the original electrons, ... ???
I've heard ALOT of excuses in my day for being too lazy/cheeeeep to fix your car; but this one descends to unplumbed depths.
FIX YOUR CAR. A car THAT WORKS is better than one that doesn't.
Old Feb 21, 2014 | 10:19 PM
scottmoyer's Avatar
As I stated, you can convert to another cooling option, just don't connect the fittings or apply the stickers.
Old Feb 21, 2014 | 10:46 PM
92GTA's Avatar
https://www.thirdgen.org/forums/cool...06a-video.html
Old Mar 10, 2014 | 09:22 AM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Read what Scott posted. End of necessary discussion.
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
