Formula 350 drag test (vintage)
Old Oct 17, 2018 | 02:21 PM
  #51
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Formula 350 drag test (vintage)
but if they didnt adjust cooling fan turn on temps the stat would do nothing but delay how long it takes to hit max temp. Fans would be required to keep 160’s
Correct,fans fans play a big roll in keeping these cool. A quick track trick is grounding the wire at 2nd fan switch in the pass head or even putting it on a ground side switch.
Old Oct 17, 2018 | 03:07 PM
  #52
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
On early single fan TPI cars I jump across the AC pressure switch, worked on my '86 back in the day LOL. You guys make me feel old...
Old Oct 17, 2018 | 04:28 PM
  #53
TTOP350's Avatar
I always say, "back when I was cool" . lol
Old Oct 17, 2018 | 04:32 PM
  #54
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah i grounded the head side on a switch to keep it running while car was off to cool rad. Icing the tpi plenum was almost always a 0.1 et improvement for me. It heat soaks bad. Even my stealth ram did good with iced plenum
Old Oct 18, 2018 | 06:48 AM
  #55
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
LOL nothing screams the 90s like having your hood up in the staging lanes with a bag of ice on a TPI or LT1 intake manifold.
Old Oct 18, 2018 | 08:58 AM
  #56
TTOP350's Avatar
Oh the memories.. lol tools, jack, tires and cooler full of bagged ice and dry towels to put under the ice bags on intake so water wouldn't run onto the track..
Old Oct 18, 2018 | 09:08 AM
  #57
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
indeed lol i still have cooler full of ice but to put into my intercooler tank lol
Old Oct 20, 2018 | 10:12 AM
  #58
TTOP350's Avatar
Incase there are any vintage cone killers out there
Old Oct 23, 2018 | 09:26 PM
  #59
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Old Oct 27, 2018 | 10:50 AM
  #60
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
At one point I was getting over 10 magazines a month from the early to mid 80s and I still have most of them. Sadly, I'm getting zero a month these days.
I used to really look forward getting GM High Tech Performance back in the day until they got bought out and replaced by I think Chevy High Performance. High Performance Pontiac was good too.
Old Oct 27, 2018 | 03:15 PM
  #61
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
That car in the first article is a literal clone of my 88 Formula. Although I never read that article until today, I had similar results in 2006-07 when I first bought the car (w 50k miles for like 3500 bucks). Once it was tuned up it ran consistent 14.70's stock and would get worse the hotter the engine got. I installed a SLP cold air, 180 thermostat and a edelbrock aftercat and the car would go 14.20's-30's all the time. Similarly I found heat to be the biggest issue, I removed the scoop block off plate and would push the car through staging with the hood up. Then I stored the car for like 10 years. Me and a buddy got it out of storage last year, tuned it up again and installed some dyno dons before we drove it from Cincinnati to St Lois for Roadkill Zip tie drags. It went 13.90's/14.00's picking up 4 mph in like 95 degree heat running at 210 degrees. I could literally bare hand grab the header before I could touch the intake runners, TPI is a heat sink.
I never bumped the timing beyond the stock 6 degrees, but this car has always dead hooked on street tires. Ive broke the trans mount twice in it.
Old Aug 10, 2020 | 08:05 AM
  #62
TTOP350's Avatar
Some info on Nick Fusco's formula.
http://andy_79_z28.tripod.com/id19.html
Old Aug 10, 2020 | 11:46 AM
  #63
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
I’m guilty of this 90’s practice as well 😂
Remember being at the track one time with this old guy that ran an exhaust shop locally. This would have been around 1996 I’m guessing. He had purchased a new 93 Ford Lightning a few years prior and had a Paxton supercharger installed. Truck would run solid low 14’s on street tires. He saw me icing my intake and asked what I was doing. Long story short, sends his grandson to concessions to get a back of ice. Cools it down, makes a 13.80 pass next run and something in the engine lets go.
Old Nov 26, 2024 | 02:20 PM
  #64
TTOP350's Avatar
Slp test car
https://www.thirdgen.org/forums/hist...beginning.html
88IROCvertZ
Sep 28, 2019 04:19 PM
Linson
Dec 18, 2016 08:10 PM
chickenhawk
Oct 7, 2006 10:16 PM
Zepher
May 12, 2005 01:03 PM
BoneStockBird
Mid-West Region
Feb 9, 2005 08:00 PM
