My '89 IROC Z Vert does not have.................
Engine: LB9 305
Transmission: AT
Electrically operated Tonneau release, nor electrically operated deck-lid release. It DOES have electric deck-lid pull-down. Is this OE? The copy of the factory order form does NOT list or mention electric tonneau or deck lid release. Thanks.
Re: My '89 IROC Z Vert does not have.................
The pulldown is a carry over from the hardtop, up until GM changed the design in mid 91, they all have it. Mid-91-92 have a standard latch.
The electric tonneau release should be there, normally it takes the place of the trunk release button/feature. Can't say I've ever seen one that didn't have it, but then I haven't really looked for it specifically. fwiw.
Engine: LB9 305
Transmission: AT
Does anyone know, with certainty, if they built 1989 IROC Z VERTS that only have the 2 power window switches, on the console? IE NO power decklid (trunk) release and NO power Tonnau release? It does have the trunk pulldown. That is what I have, but the interior was changed from it's original RED to BLACK.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I can't say there was never a power release for the tonneau cover, but I have never seen one that was not a manual release/manual top. I believe since they were all outsourced to be made into convertibles, you just got manual cover/top. Does seem weird you do not have a power release for the trunk as it would have released the same way a coupe's hatch would.
All the convertibles I've seen either have the standard trunk release switch with a picture of a tonneau cover on it, either in the usual place in the console or on the tonneau itself behind the driver's seat, next to the top release. Pull the top release, fold the back of the top up, press the tonneau switch, open the tonneau, fold the top down into the well, close the tonneau.
Without the remote switch to release the tonneau, you have to add the additional step of releasing the tonneau on both sides of the car, by folding down the back seat and fishing around for the manual release cables.
Usually, the convertibles don't have a power trunk release. Pull-down yes, remote release no. Among other issues, if the tonneau and the trunk are opened at the same time on a convertible thirdgen, it'll damage one or both since they would try to occupy the same space. It makes sense that ASC repurposed the trunk function for the tonneau function when you consider which would be used more frequently, cost savings, avoiding someone accidentally hitting both switches and damaging the car, the limited trunk space, etc and so on.
Engine: LB9 305
Transmission: AT
OP Here. I suspect when the Knuckleheads who converted my IROC Z from red/black interior to black/gray, removed the console, they installed a console with ONLY the 2 power window switches. I won't know till I get into the interior restoration, months from now. I am very querious!
