Compnine a VIN
Old Oct 4, 2019 | 04:50 PM
IRocN87's Avatar
Car: 87 Iroc w/ T-tops
Engine: LB9
Compnine a VIN
Could someone run this VIN and post the results?
Edit: JT has scanned it for me!
The site says it has a full build sheet, it's just hidden behind a membership fee
Old Oct 4, 2019 | 05:16 PM
JT's Avatar
JT
Community Administrator
Re: Compnine a VIN
Don't put too much into the definitions as Compnine uses a universal/generic definition per RPO code and GM changed RPO code definitions over the years. The RPO code itself is the important info.
1AY ORDER MODIFICATION - STOCK
1HV COMPONENTS OF IROC-Z PERFORMANCE PACKAGE COMPONENTS OF B4Z IROC-Z PKG(1HV)
15P WHEEL COLOR,MEDIUM SLATE GRAY (15P)
19C TRIM COMBINATION,CLOTH,BLACK (19C)
19I INTERIOR TRIM COLOR (19I)
199 SEAT BELTS COLOR BLACK (19) (199)
6ZX Unknown
7ZX Unknown
8NL Unknown
81Q MOLDING COLOR - BRIGHT RED (81Q)
81U EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
86A ACCENT STRIPE,TWO-TONE,LIGHT SILVER/BLACK (86A)
9NL Unknown
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A01 WINDOW,TINTED GLASS(ALL WINDOWS) TINTED GLS(A01)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)
BS1 INSULATION,ACOUSTICAL INSULATION PKG(BS1)
B18 ORNAMENTATION,INTERIOR(DELUXE) DELUXE INTR(B18)
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B4Z IROC-Z PERFORMANCE AND APPEARANCE PACKAGE IROC-Z PKG(B4Z)
B48 TRIM EQUIPMENT,LUGGAGE COMPARTMENT(DELUXE) LUGG COMPT TR(B48)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
B9K ORNAMENTATION - B/S MLDG REAPPLY TO RR DOORS ONLY
B94 ORNAMENTATION,EXTERIOR,BODY EMBLEM BODY EMB(B94)
B97 ORNAMENTATION,EXTERIOR,LOWER MOLDING ACCENT LWR ACNT MLDG(B97)
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
CD4 WIPER SYSTEM,WINDSHIELD,PULSE PULSE WPR(CD4)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DK6 CONSOLE,ROOF RF CNSL(DK6)
D08 PAINT,HIGH-GLOSS FINISH HIGH GLOSS PAINT(D08)
D34 MIRROR,INSIDE,SUNSHADE S/S MIR(D34)
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35)
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
D6F Unknown
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80)
D88 STRIPE,SPORT SPORT STRPE(D88)
E5Z ADAPTER - SPEEDO - DELETE
E7Z SENSOR - VEH SPD - DELETE
E9Z KEY - SPEEDO - DELETE
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)4,732
K68 GENERATOR,105 AMPERE 105 AMP(K68)
LB9 ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
NOD Unknown
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
N65 WHEEL AND TIRE,SPACE SAVER SPARE(STEEL) STOWAWAY SPARE(STEEL)(N65)
N96 WHEEL,16X8(CAST ALUMINUM) AL WHL(N96)
PB4 LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4)
P20 CAP,STYLED WHEEL HUB STYLED WHL HUBCAPS(P20)
QDZ Unknown
TR9 LAMP GROUP,COURTESY LP GRP(TR9)
TT4 HEADLAMPS,TUNGSTEN QUARTZ HALOGEN HALOGEN HDLP(TT4)
T93 LAMP,TAIL AND STOP(SPECIAL) SPECIAL TAIL & S/LP(T93)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6)
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
U21 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,TACHOMETER,VOLTMETER) GA CSTR(U21)
U25 LAMP,INTERIOR,REAR COMPARTMENT COURTESY RR COMPT CTSY LP(U25)
U26 LAMP,INTERIOR,ENGINE COMPARTMENT COURTESY E/CMPT CTSY LP(U26)
U29 LAMP,INTERIOR,INSTRUMENT PANEL,COURTESY I/P CTSY LP(U29)
U75 ANTENNA,POWER(CHROME) PWR ANT(U75)
U79 SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(U79)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
V73 Unknown
X07 Unknown
YR1 SEAT,FRONT(CUSTOM) CUSTOM ST(YR1)
YS1 SEAT,REAR(CUSTOM) CUSTOM RR ST(YS1)
YT1 BUILD-UP,CUSTOM DOOR AND QUARTER CUSTOM DR & QUARTER(YT1)
YT9 FLEET PROGRAM - EXPOSURE INITIATIVE I: C/F/G/H/J/K/M/N/S/U/V/W/Z- TRK CKGMPST
Z28 PERFORMANCE PACKAGE,SPECIAL PERF PKG(Z28)
Z31 IDENTIFICATION - PRICE SHEET ADVANCE
Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49)
Old Oct 4, 2019 | 06:23 PM
IRocN87's Avatar
Engine: LB9
Re: Compnine a VIN
Thank you!
Old Oct 5, 2019 | 04:20 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Compnine a VIN
FWIW, here are some of the missing RPO's that I found:
6ZX - SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX - SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
9NL - SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
(No Rear, Left Hand??)
QDZ - TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
V73 - ANTENNA, FIXED
Old Oct 5, 2019 | 07:44 AM
IRocN87's Avatar
Engine: LB9
Re: Compnine a VIN
Ahhh, no wonder my car squats so low... I only have 1 spring in the rear!!
Jk, I'm thinking the code 8NL is the rear left, likely part of the "upgraded" iroc suspension package. The fixed antenna is odd tho, considering I also have U75 (power antenna).
Also, I'm a little confused. J65, G80, GU5, KC4... But no G92? I thought you needed the G92 code to get a combination of all of those?
Old Oct 18, 2019 | 02:41 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Compnine a VIN
IIRC 8NL would be the Left Spring...
Old Oct 18, 2019 | 03:40 PM
Drew's Avatar
Re: Compnine a VIN
What you have to remember is that a code only needs to be there to differentiate combinations of parts. Look at the 87 drivetrain chart in the tech data. Notice that G92 was only optional on certain engine/trans combos. The key word is optional. If there was a choice (Option) between two ratios, the "performance ratio" of the two would have G92 on the SPID. When an engine/trans combo only had one available gear ratio, G92 wouldn't apply because it was standard, not optional.
Edit: Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49) might have something to do with it too... Export cars frequently had to have certain substituted equipment. If all logical explanations don't add up, being an export is likely the culprit.
89formulalt1
Oct 26, 2008 08:22 PM
5.0L1992RS
Oct 7, 2002 09:53 AM
BadBird84
May 11, 2002 07:59 PM
