86 TA with DX3
Old Mar 10, 2021 | 07:59 PM
nothingssafe's Avatar
Car: 86 TA
86 TA with DX3
Looking at the Pontiac literature and the order worksheet(6/85) I do not see this option. I searched and did not find any info on this RPO with the Pontiacs, just the IROCs. My car is a later build - last six is 244239, Any info out there? Full RPO list:
AAA : 4-WAY MANUAL SEAT ADJUSTER
AK1 : BELTS, FRT CTR, RR ST & FRT SHLDR (DLX)
AM9 : SEAT ASM, RR SPLIT BACK FOLD DOWN
AR9 : SEAT ASM, FRT BKT RECL (EUROPEAN STYLE)
AU3 : LOCK, SI DR ELEC
A01 : WINDOW, DEEP TINTED GLS (ALL WDOS)
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BV3 : ORNAMENTATION, INTR, I/P, BLACK
B20 : ORNAMENTATION, INTR, LUX
B34 : COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS, CARPETED INSERT
B60 : DECAL PACKAGE, 01
B67 : BOX, STORAGE, CASSETTE TAPES
B84 : MOLDING, BODY SI (BLACK)
B87 : EMBLEM, FENDER (DELETE)
B97 : MOLDING, EXTR LWR ACCENT
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DX3 : STRIPE, DELETE
D14 : ARM REST, FRT DR, RH & LH
D3W : GEAR, SPEEDO DRIVEN
D34 : MIRROR, VISOR VANITY
D35 : MIRROR, OUTSIDE REAR VIEW
D81 : SPOILER, RR, AERO WING
D9A : SENSOR, VEH SPD
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
GH3 : AXLE REAR, 2.77 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K90 : GENERATOR, 108 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : WHEEL, STRG (FORMULA)
N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
N33 : STEERING COLUMN, TILT TYPE
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
PB4 : LOCK CONTROL, WHEEL
QAC : P235/60VR15 BSW STL
TR9 : LAMP, GROUP
T93 : LAMP, TAIL & STOP (SPECIAL)
T96 : FOG LAMPS - FRONT
UF6 : LAMP, INTR, CONSOLE, COURTESY
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UT1 : TONE GENERATOR, WARNING
UX1 : RADIO, AM/FM STEREO, CASSETTE, EQUALIZER
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 : LAMP, LUG COMPARTMENT
U29 : LAMP, INTR I/P, COURTESY
U66 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
VAN : ASSEMBLY PLANT, VAN NUYS, CA
V73 : USA/CANADA VEHICLE STATEMENT
WS4 : MODEL CONVERSION, TRANS AM
WW6 : AERO PACKAGE, FLAME RED METALLIC
W62 : AERO PACKAGE
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7DB : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
74Q : MOLDING COLOR, FLAME RED MET (91)
74U : PRIMARY COLOR, EXTERIOR, FLAME RED MET (91)
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
84P : WHEEL COLOR, GRAY (91)
9NB : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Old Mar 10, 2021 | 09:56 PM
JT's Avatar
JT
Community Administrator
Re: 86 TA with DX3
Do you have the perimeter stripe on the lower body and front and rear bumpers? I believe the DX3 deleted that stripe as it was otherwise standard.
There is little information on it other than another member here, years ago, shown me their SPID/RPO sticker from their own 1986 Trans Am with the same DX3 code and their Trans Am did not have the perimeter stripe.
TR9 : LAMP, GROUP
W62 : AERO PACKAGE
YS1 : SEAT,RR CUST
Old Mar 11, 2021 | 12:58 AM
Car: 86 TA
Re: 86 TA with DX3
The car was repainted roughly 13 years ago. There are no stripes on it currently.
Old Mar 11, 2021 | 03:18 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: 86 TA with DX3
Code DX3 shows that your car never had stripes, which is probably why stripes weren't applied after the repaint.
86 Trans Ams(and 85), were available two-tone or monotone, unlike 87 TAs, which were only available two-tone, because the new GTA took over the monotone scheme. Your code WW6 shows the GFX matched the car's primary color, code 74U, so it was monotone from the factory. Both schemes, monotone and two-tone, received a dot-matrix stripe above the GFX, similar to a two-tone Z28 and a monotone IROC and each's solid color stripe.
I can't say I've ever seen or heard of any of the two-tone schemes having no stripe from the factory, so those probably didn't have stripe delete option DX3 available to them. Whereas monotone schemes apparently could be had without the stripe, but the person placing the order(dealer or customer) probably had to know the material very well, because most monotone cars weren't ordered without a stripe.
Old Mar 12, 2021 | 06:22 PM
Car: 86 TA
Re: 86 TA with DX3
Yes, that is what is puzzling to me as well because the 86 Firebird car order work sheet that is posted on this forum does not mention any option of it, but the form is also from dated 6/85 so it may have been a late option available later on that I can't find literature on. Does anyone have a later work sheet?
I'm also curious if the stripe delete removed the other graphics on the car, like the Trans Am and Firebird logos. Possibly moved the Trans Am logos lower on the bumpers? 🤷‍♂️
Old May 21, 2021 | 04:18 PM
Car: 86 TA
Re: 86 TA with DX3
Update!
I found this bulletin while browsing a different thread. I also looked through the 82-92 GM F Parts and Illustration Catalog and found that stripe delete also removed the nose and sail panel Firebird emblems. If anyone has a later 86 Firebird order worksheet please post it up.
osso12
Jun 14, 2024 10:04 AM
Twin_Turbo
Members Camaros
16
Aug 9, 2009 04:15 PM
Twin_Turbo
Dec 6, 2008 03:38 PM
Daishi
Dec 5, 2006 06:20 PM
BigMike1610
Apr 19, 2003 08:27 PM
