WHICH Flywheel do I have....
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
OK this might go in motor swap BUT you history guys know ALL..
I have an 82 Z28 with Borg warner 4 SPEED....
so do I have a "normal" 168 tooth flywheel?
as in any 1955-86ish block, crank etc.
The reason I ask is the 383 needs a "400" (externally balanced)
flywheel to work so, if I just buy say a Hays SFI aprroved 400 flywheel will it work, or what about one from GM for a 400? (169$)
THANKS FOR your help, DAVE
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
