General Questions about my 89 GTA
Old Sep 17, 2021 | 05:25 PM
linkdan2000's Avatar
Hello all, first post here...
I just got an 89 GTA recently and wasn't sure about the authenticity of it. I ordered the information from GMMediaArchive and the only thing on the document sent was Y84, Y5F, and L98. My question is that it has a 5 speed in it, but I read that not 5.7s came with a 5 speed. Did the owner swap it? It looks all original and I was told by the owner it was, there also appears to be a hydraulic master cylinder for the clutch, I could be wrong. Any information is appreciated, I am fairly new to classics and would like to learn more.
Thank.
Old Sep 17, 2021 | 05:32 PM
PaulyC's Avatar
Re: General Questions about my 89 GTA
Y84 is the GTA option code so that's a good sign, On the engine, check the 8th digit of your vin number and that will tell you what engine came in it.
Old Sep 17, 2021 | 05:33 PM
8th digit is an 8 so that means 5.7 right? Which is that GMMediaArchive told me.
JT's Avatar
JT
Community Administrator
Thank.
Y84 is the GM code for GTA from 1987-1992. L98/B2L is the GM code for the 350. VIN code 8, in the 8th row of the VIN, is the 350.
There was no L98 with the manual transmission, from the factory, for the general public during the ThirdGen (1982-1992) production. So, if you have the L98 and a manual transmission, it's not factory.
Look at the inside wall of the center console for the SPID sticker. It will have the VIN and several 3-character codes that each define the options on the car as left from the factory. Look for MX0. MX0 is the automatic transmission. However, since the transmission was likely swapped from auto to manual, the console may not have the SPID sticker or it may not be original to the car.
Post the GM Archive invoice. I thought the transmission was listed (for example: MX0 for auto and MM5 for 5-speed manual). Then again, the invoice does not list every single RPO code so that it's missing does not imply significance.
Old Sep 17, 2021 | 05:38 PM
File Type: pdf
PaulyC's Avatar
That is correct, how sure are you on the originality of the transmission? That can be swapped too. Did the GMMedia say anything about that?
Old Sep 17, 2021 | 05:43 PM
JT's Avatar
JT
This car?
https://topclassiccarsforsale.com/po...ver-400hp.html
It's not factory - from the aftermarket hood to the "engine built over 400hP" 355 engine. That alone makes it pretty likely the transmission is not original.
Old Sep 17, 2021 | 05:49 PM
Yeah that's it, didn't buy the motor, I have a 350 from a corvette I want to build... I guess I am going to have to lift it up and see what transmission is inside then. Regardless, no way there is an original 5 speed is what I am understanding
Old Sep 17, 2021 | 05:52 PM
PaulyC's Avatar
Maybe you will get lucky and find a TKO tucked in there but if it is a T5 it won't last long if you feed it any decent power.
Old Sep 17, 2021 | 06:04 PM
84T/A_GearHead_'s Avatar
Car: 84 Trans Am
Engine: 400ci w/69 350 heads
Transmission: Borg Warner T5 MM5 MK6
Axle/Gears: LT1 3.45
Ad says 6sp trans
Old Sep 17, 2021 | 06:11 PM
Originally Posted by 84T/A_GearHead_
Ad says 6sp trans
best pic I can get of the trans. Can’t move the transmission around to check bell housing stamp. Any chance you know what it can be by pic?
Old Sep 17, 2021 | 06:22 PM
this weekend I should be able to lower and get better pics and hopefully find the stamping
Old Sep 17, 2021 | 08:37 PM
Car: 84 Trans Am
im not the best to answer but it looks different to my t5 and ad said 6spd so im thinking its a t56
Old Sep 17, 2021 | 10:50 PM
vorteciroc's Avatar
Top Answer: 1
It is a Borg-Warner T56 6-Speed Transmission for Gen-1 and Gen-2 SBCs.
Also the Electrical-Connector can clearly be seen hanging down, for the original THM700-R4 Torque-Converter Lock-Up Circuit.
Old Sep 18, 2021 | 08:26 AM
Yup, it's the LT1 T-56 from a 94 - 97 F body. The version with the pull clutch.
Doesn't look like it has ever worked in that car yet. I see no evidence of hydraulics on the firewall.
Old Sep 18, 2021 | 07:55 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
It may not be original, but it WILL be fun!
Cambridge205
Sep 10, 2016 04:26 PM
Ls2 GTO
Members Firebirds
Sep 4, 2008 07:33 PM
youngbuck007
Nov 8, 2007 04:20 PM
lildegen
Nov 10, 2002 11:02 PM
