Camaro questions
Engine: 4++,350 & 305 CIs
Re: Meaning behind the 1/98 metal tag under the hood
What kind of history do you know about the car?
Not sure ive ever seen that on a gm part. I'm not seeing any GM decals on the bottom of the hood either, wondering if the hood has been replaced?
do the hinge to hood bolt heads look like they've been in or out? Chips missing on all sides of the head flats?
Car: 1988 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 2.77 Posi
TKY is/was a manufacturer of replacement automotive (and other parts) based out of Taiwan. Your original hood has been replaced at some point.
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
the 98 on the bolts is the type of strenght the bolt has in metric.
standard has grade 5, grade 8 etc, metric has their own ratings.
the hood and whatever else that has the 1/98 logo means it is aftermarket parts.
been replaced do to a fender bender or some type of damage.
sorry to burst your bubble.
Car: 90 Formula / T-tops
Transmission: MD8
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Original class 9.8 bolts,Taiwan aftermarket hood- probably made 1/98...
