i need 86 T/A info.
Old Jan 31, 2002 | 08:45 PM
ICE305's Avatar
i need 86 T/A info.
as my last post says i just got a 86 T/A with the 305 TPI with the preformance suspension badge and power everything,T-Tops, it also has flow masters from the cat back and K&N filter, does anyone now the stock numbers on this thing,(HP, torque ) and also what is stock oil pressure on these mine is usually 60+ when i start it cold then when warm around 30 is this normal?or do i have a high flow pump? and what is normal running temp.? like i said i need info. i'm new to this. Thanks to anyone who can educate me in advance.
Old Jan 31, 2002 | 09:09 PM
karfreek's Avatar
LB9 _(V8) 5.0L / 305 C.I. 9.5:1 190@4000 RPM 285@2800 RPM Tuned Port Injection
That is normal for the Oil Press! Mine does the same, pegs the gauge way past 60psi, then hovers near 30psi when at a hot idle.
If I am moving at highway speed, my temp is about 170. The fans kick on near 220.
Jay
Old Jan 31, 2002 | 09:57 PM
ICE305's Avatar
thanks for the figures but 190 is that torque or HP either way isn't that a little low?
Old Feb 1, 2002 | 12:09 AM
Tonyrodz's Avatar
Transmission: auto
190 is the hp--they rate it at the flywheel. There's usually a 20% parasitic loss at the rear wheel.
Fanatic1074
Oct 3, 2022 05:57 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
F-body-fan
Nov 4, 2015 06:13 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
