Steering column for '86 Maro
Old Sep 16, 2006 | 01:29 PM
theredline's Avatar
Car: 86 iroc
Engine: the 305 tpi that could
Transmission: soon to be WC 5spd
I am sick of trying to fix a switch here and there. Sick of being able to turn the car on without a key. I just want a working 86 camaro steering column or one that will fit in that year.
It has to have....
No cruise control, Hi or Lo Wiper Switch (Pulse correct?), Signals work, and Key Actually Locks.
Most importantly Hi-beam switch and rod that isn't broken or bent. Don't need steering wheel.
Will buy ASAP. Need to pass inspection
Old Sep 16, 2006 | 02:02 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
may be getting a 85 parts car with 5spd column let me know if your interested
Old Sep 16, 2006 | 02:34 PM
theredline's Avatar
Car: 86 iroc
If you have all that above that I need, I'm interested. Let me know ASAP when you get the parts car.
Old Sep 16, 2006 | 02:57 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I have a 84 trans am column. very nice, has tilt, cruise, intermitant wipers and comes with a key. it came from a automatic car, does not come with a steering wheel
45 + shipping
Old Sep 16, 2006 | 03:02 PM
theredline's Avatar
Car: 86 iroc
45 + shipping
1) Are intermitant wipers the ones with Hi or Lo option only?
2) Hi-beam switch work?
3) What if I don't have cruise control? Will it work?
4) Does key cylinder lock all the way down? Very important.
I'm all ears. If so, then we can work out with paypal.
Old Sep 16, 2006 | 05:53 PM
Jproz1167's Avatar
intermitant wiper are the kind that pause a few seconds then wipe
if your car doesn't have cruise then the switch wont make anything work
yes everything works perfectly on the column. and it has no tilt wobble common in alot of columns, it is factory black and has never been dyed a different color. I will pull it out of my garage and double check it though.
why don't you just fix whats wrong with yours it would be alot cheaper and less work. all you need is a steering wheel remover and lock ring depressor to fix the column. it's easy to replace anything like whats wrong with your column
Old Sep 17, 2006 | 02:02 PM
theredline's Avatar
Car: 86 iroc
I could fix it. Here's whats wrong.
My wiper switch is for a delay, but I have intermitant wipers.
The key wont turn all the way down to lock. Only goes close enough. I don't know how to fix that. Anyone can just turn it without a key and start the car. I don't want that. My old key cylinder is sobad so i can pull that key out in any position (ON or start). I switched the key cylinder and it still wont go all the way down.
Old Sep 17, 2006 | 08:16 PM
driver101's Avatar
got the parts car it has no cruise no delay wipers can install if needed 45 plus shipping can send out tuesday if have to change switch or monday if you don't have delay wipers
luke
Old Sep 18, 2006 | 11:33 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
got one
i have one thats actually from a 86, it has a tilt wheel.
$55 shipped with wheel
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
