Need a cluster panel w/bezel & black center console
Old Apr 8, 2008 | 08:48 PM
laintocable's Avatar
Car: 89 firebird
Engine: 400 sbc/forged/alum/supercharged
Transmission: TH350, manual valve body
Axle/Gears: posi 390/4 whl disc
I am looking for a cluster panel with cluster bezel in super great conditions. Here's the thing I have an 89 firebird (which comes all computer controlled, so theres no speedo cable), but I'm using a 72' 400 sbc/TH350, this tranny comes for a speedo cable. So what I believe I need is an early 3rd gen cluster, which I think came in the 82's and I dont know how much later they made them..I am running all Autometer guages (water,oil,volts,and since It's a blown motor vacuum boost gauge...but I won't have a speedometer or odometer until I find the right cluster. Also need a perfect condition complete automatic center console in black with both driver and pass side power window switches and arm rest (complete!).....Any suggestions will be gladly appreciated on this cluster, Thanks in advance! If not local, shipping would be to Tampa,Fl 33635.
Old Apr 9, 2008 | 07:01 AM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: Need a cluster panel w/bezel & black center console
Well since your running all aftermarket gauges why don't you just finish up with an aftermarket spedo and tach and make a custom filler panel. or you could use a speed signal generator I think dacota digital makes them. I have a bezel with the 4 large holes for gauges if you are interested in that. sorry all my clusters are digitaly driven.
Old Apr 10, 2008 | 05:33 PM
Car: 89 firebird
I have the big tach with shift light, I just need a miles per hour with an odometer.
Old Apr 12, 2008 | 07:31 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
You can buy a VSS for your TH350 to change it to electrical from mechanical. That would be the easiest way and the cheapest.
I have a complete black CC from a 89 GTA in very nice condition. Perfect, you will have to buy NOS.
Old Apr 12, 2008 | 10:58 AM
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
If I were you I would devinatly just buy an autometer spedo that maches the rest of your gauges and just make a filler danel out of stanles and call it a day. but if you want an older cable driven spedo cluster they are out there I belive they were in the 82-84 pontiacs.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
LittleFranks
Sep 17, 2015 12:22 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Firebird sweden
Aug 16, 2015 05:02 PM
