85-89 V6 Camaro Black Gauge Cluster
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
[CT] Was wondering if anyone has a black 85-89 working gauge cluster with the Speedo 85, 120, 145 doesn't matter, oil pressure HAS TO BE 80 PSI GAUGE, temp gauge, charge gauge, and fuel gauge. I have the stupid lights..
and how much can I get it for, looking for prices, looking to get one for $60 - $75 shipped to CT? If possible.
Car: 1986 Camaro Berlinetta
Engine: 2.8L Multi-Port Fuel Injected
Re: 85-89 V6 Camaro Black Gauge Cluster
I have a gauge cluster with the lights still in that I pulled from a 25th Anniversary 92 RS. It is a 110Mpg gauge and has roughly 108,000 miles on the odometer. I currently have the item on ebay. I have included the links to some pictures for view, the only problem that I can see with the cluster is the clear plastic cover which is cracked near the bottom. If you're interested please provide a zipcode and I'm sure I could probably do $80 Shipped.
http://i264.photobucket.com/albums/i...Gaugefront.jpg
http://i264.photobucket.com/albums/i...SDC13069-1.jpg
Axle/Gears: 10 Bolt
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
[CT] Was wondering if anyone has a black 85-89 working gauge cluster with the Speedo 85, 120, 145 doesn't matter, oil pressure, temp gauge, charge gauge, and fuel gauge. I have the stupid lights..
and how much can I get it for, looking for prices, looking to get one for $75 shipped to CT? If possible.
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Not sure if you need this or not at this point but i have an 85-89 guage cluster for your camaro. It is the V6 model with the round guages and not the half moon ones. The red line starts at 50 on the tach 11023 K and 115mph speedo. $60 Shipped in U.S.
Lmk
Thx
Ray
Lmk
Thx
Ray
Axle/Gears: 10 Bolt
Some of the clusters differed between years and also if it was an auto or manual -mostly the lights along the bottom. Also, with the dummy lights, you're probably going to need to rewire the sensors for the gauges to work. That being said the cost of the cluster will depend mostly on the speedo where a 110mph may be around $50 or so while a 145mph can range upwards of $100 or more. You're best bet is to get something from a junkyard especially a Pick-n-pull where you could even try getting the sensors as well. It shouldn't be anything near $80 for a 85mph speedo. Don't forget that you also need to match the tachometer with the engine you have. Ie. V6 for V6 or V8 for a V8.
Axle/Gears: 10 Bolt
Side note, I believe if the red line starts at 50 it's for a V8, what's the oil pressure end at 60 or 80?
Engine: 6.0 Vortech
Transmission: 4x4
Can I get some pictures in here or a private pm? and do you know if all the gauges work? kind of the reason why I am getting new ones..I dont have any old gauges to replace any broken ones.
Ray
Engine: 6.0 Vortech
Transmission: 4x4
Yes I know I need a V6 model cluster, and it is an automatic, the only sensors that need to be changed are the oil pressure, and the coolant sender ($25 for both really cheap stuff). I read around and was told many times that the dash harness comes with all the wiring needed for an 85-89 cluster with all gauges as long as I change the senders so they can be used for gauges.
I am sorry, mine is for a Camaro not a Firebird. My bad I didnt read it right after the one dude said the 92 RS thing. LOL . Threw me off ever since.
I dont think its what u need.
Ray
Axle/Gears: 10 Bolt
Engine: 6.0 Vortech
Transmission: 4x4
No I'm looking for a camaro cluster..don't let my avatar throw u off or my sig, email is xxxchrisgxxx@yahoo.com
Thx
Sending pics
Ray
Axle/Gears: 10 Bolt
still looking! need a V6 Camaro cluster! 80 PSI Oil Gauge please
heard bad things about switching from a V6 cluster to a V8 cluster, so I am looking for that V6 cluster.
heard bad things about switching from a V6 cluster to a V8 cluster, so I am looking for that V6 cluster. Thread
