[MD] Steering column
Old Nov 2, 2010 | 10:55 AM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Steering column
I need a steering column for a 1989 Trans Am automatic. ship to 17325 or 21788
Email Rockmann007@yahoo.com
Old Nov 2, 2010 | 11:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Steering column
$125 + shipping. Includes the ignition and VATS box.
Post your ZIP code for a shipping quote if your interested.
Old Nov 2, 2010 | 10:26 PM
TA-Rocks's Avatar
Re: Steering column
Ok, can you get the whole thing to me with the bottom part of the steering shaft? They would have to be pressed together with a machine otherwise. Can you send a pic?
I have the new Vats ignition switch module
Robert 240-393-7625
Old Nov 3, 2010 | 08:35 AM
John in RI's Avatar
Re: Steering column
The column is sold as a complete unit, It's sold just as it is when removed from the car. This one is from an 89 FireBird Formula.
Here's is a picture:
After pulling it out I found the following,..... It's an Automatic Column with Tilt Steering. The Blinker control has "delay" wipers and it has a VATS ignition key and Module that was in the same car. The Tilt control, blinker lever, and ignition switch are all tight and not sloppy, the plastic around the column is also in good shape, I found 1 scratch. Chip Key included.
I also found - what appears to be - a resistor spliced into the VATS ignition harness. ( see pic ) I did not unwrap it to verify, but what else could it be. I do recall that the car started; I don't know if the resistor bypassed the module or not. The steel steering wheel hub attached in the picture is NOT included. That's a Berlinetta specific part and I need it for that type of steering wheel.
Shipping: I used ZIP code 17325 - GETTYSBURG, PA. All quotes include $125 insurance coverage, tracking included with 'ground' - Add $1 for USPS Delivery Confirmation.
USPS Parcel:$18.00
USPS Priority: $22.50
Ground: $18.00
If your still interested just send me a PM for the rest of the details.
Old Nov 8, 2010 | 05:38 PM
TA-Rocks's Avatar
Re: Steering column
Does this one have the cruise control switch on the blinker multiswitch? Can you ship this column to me for 100? If thats good we can go ahead with it.
Old Nov 9, 2010 | 05:23 PM
John in RI's Avatar
Re: Steering column
I'd rather hold onto this one instead of selling it cheap,....... Sorry I can't help !
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
