[WV] steering column
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
steering column
I'm looking for a steering column, key, and vats box for a 1989 IROC automatic. I need all the female harnesses to still be attached to the column and must be in good working order. PM me if you can help me out. Thanks.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: steering column
I've got 1 with Key and Vats Module.
The VATS box from the same car is tapped to it. BUT; I do not know if it's needed.
The VATS key cylinder wire harness ( Orange and White wires ) have a small bundle of electrical tape on it.... I think it's probably a VAT's Bypass. The whole car was a very original 89 Fomula and I was sure to keep the original VATS module with the column in case it was actually needed. (The car ran before I stripped /scrapped it.)
P.S. Don't know if I have harness pigtails - but I'll look it you need this column. Post your ZIP code for shipping estimates.
sjorgens
Oct 1, 2015 07:54 PM
