[IL] delete please
Old Nov 14, 2012 | 08:16 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
delete please
Old Nov 14, 2012 | 09:09 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: WTB B&M Megashifter
$60 + shipping.
Shifter works fine through-out the entire range, but it needs parts to make it complete. I know it needs the floor bracket, a trigger, & and handle. There's a shift bezel, but the gear indicator on it doesn't slide. The Shifter IS for a 700R4 - I got the shifter, cable, and boots from the same car. The bezel (& indicator window) were from another (early) ThirdGen. Bezel fits over all factory 82-92 Camaro Bezels. No reverse light wiring.........
Basically the shifter, the 700R4 Cable/Boot, a shift bezel, and a useable shifter boot. (had a crack that was re-sealed) Post your ZIP code for a shipping quote if your interested.
Old Nov 14, 2012 | 10:53 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
$60 + shipping.
thanks for the offer but i would like to find one a little more complete,idk if id be able to find the brackets and shift plate w/ indicator individually
Old Nov 15, 2012 | 08:38 AM
my82roc's Avatar
Car: 89 Iroc Convertible
I have 2 but this is the better one.I also have the other floor bracket(not pictured).It does need a handle.Id do 90 shipped on it
https://www.thirdgen.org/forums/inte...3-f-s-b-m.html
Old Nov 15, 2012 | 10:21 AM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
thats exactly what im looking for but the cable is $50,the handle is $25,and the brackets to mount the cable to the trans is $25,and by the time i pay the $90 for the shifter and purchase all the missing parts ill be in it for around $200 and i can get a brand new one for $210 so i would have to pass unless you could come down on the price a bit..
Old Nov 15, 2012 | 12:37 PM
John in RI's Avatar
All B&M parts are available seperately,.....
NSS is about $14
Trigger is about $16
Handle is $20 & up
Tranny bracket is about $15
Indicator is about $15
About $80 worth of parts and a easy to fab floor bracket will get my shifter complete & back into service. Like you said; the cable alone is worth about $50 so I'm not going any lower then $60 for the parts I've offered.
FYI: When I bought a brand new Megashifter years back the 700R4 indicator wasn't included and had to be bought seperately.
Old Nov 15, 2012 | 02:59 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
NSS is about $14
Handle is $20 & up
Plus the $35 shift plate and shipping for everything.. i didnt say your price wasnt fair...i said i wanted one that was a little more complete..if it had the bottom brackets id probably buy it, and you are correct, i did happen to find the indicator and everything else needed EXCEPT the indicator cable and the bottom brackets that are missing,i just want something i can bolt in and go,i dont want to have to fab anything up to make it work.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
