Power antenna connector
Old May 22, 2017 | 03:19 PM
dragonmas's Avatar
Car: 1987 Z28 Vert.
Engine: LG4: ENGINE, GAS, 8 CYL, 5.0L, 4BBL
Transmission: MD8: 4 SPEED AUTO THM700R4
Axle/Gears: GU2: AXLE, REAR 2.73 RATIO
In need of the radio side plug/pigtail/harness that connects to the relay for a power antenna on a 87 Camaro z28.Relay has 2 connectors that are different from each other.Wire colors are white green and gray.I can solder/connect the wires as long as there is a few inches of wire on the plug.
