ISO front seats
Old Aug 13, 2017 | 11:02 AM
Wesley Hooper's Avatar
Car: 1988 Camaro
ISO front seats
I have an 88 Camaro and am in search of front seats that are in good shape and will sit upright. My current seats are so worn I am stuck leaning back. Color doesn't matter because I have awesome seat covers.
Old Aug 13, 2017 | 08:36 PM
Steve86TA's Avatar
Car: To many to list
Re: ISO front seats
You can replace the side seat mechanism too. That's what is worn out
Old Aug 14, 2017 | 02:52 PM
Car: 1988 Camaro
Re: ISO front seats
how much do those usually cost?
Old Aug 15, 2017 | 10:39 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: ISO front seats
$15 each + shipping.
P.S. The thirdgen seats are famous for the backrest sitting a little bit "far". Just be sure to look to see if there is actually a problem with your hinge before paying for a replacement.
Old Aug 15, 2017 | 03:57 PM
Car: 1988 Camaro
Re: ISO front seats
That's a good point lol It needs to sit back a bit unless you're like 5 feet tall. I just assumed it was messed up because you no longer need to use the handle to fold the seat
Old Aug 15, 2017 | 07:55 PM
John in RI's Avatar
Re: ISO front seats
Most newer cars have seats where the backrest will almost sit you less than 90 degrees,.... Thirdgen buckets ALWAYS seem to have a backrest that goes to far back. In the past I've placed body clips in the recliner mechanisms' "slot" so that the seat will not sit back so far. I used a clip because a nut/bolt seemed to interfere with the mechanisms "action". Worked for me and worked for quite awhile in my step dads Firebird, but it did break in his ride after a few years. ( He's a BIG dude - needs to be something stronger than a clip for his seat ! )
Not sure; but it seems to me like the 4th gen seats mechanisms might sit the vertical backrest "higher" then original Thirdgen seat mechanisms. If I ever get around to testing that theory - I'll post about it in the Interior section !
Good luck !
Old Sep 14, 2017 | 03:35 PM
LittleFranks's Avatar
Car: 92 Z28 Hawaiian Orchid
Axle/Gears: 3.23 Posi
Re: ISO front seats
i have a set of grey front seats out of my 92 z, mechanisms are perfect. foams on passenger seat are MINT, driver side cover needs to be replaced (minor blemishes)and power driver seat. asking $200 for the pair + shipping
