windows and door locks
Old Aug 10, 2006 | 03:49 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
Transmission: 700r4 w/ b&m shift kit
so my electrical is bad somehow or need new actuators of some kind. my windows roll down really slow and my door locks dont lock or unlock all the way wen i press the door lock buttons. is this a bad fuse or just bad windows and door actuators?
Old Aug 10, 2006 | 05:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Old car which has problems common to it. Most people have luck with thorougly cleaning and lubing the tracks/mechanisms (the windows will always be slow compared to new cars, but the aforementioned should help). The door panels must be removed to reach the guts, so while you're in there, considering the info in the following link:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Aug 10, 2006 | 09:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
new brushes in the power window motors, or new switches would also help muchly (if the lube job doesn't do the trick).
Old Aug 10, 2006 | 09:25 PM
camaroboricua's Avatar
Car: 1990 Camaro RS
Engine: 355 c.u.
good advice guys, i have the same problem in mine...
Old Aug 10, 2006 | 11:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
with slow window motors i usually always have good luck with them when i take a can of penetrating oil nd spray down the tracks and everything inside the doors
usually always speeds them up
good luck
my86bird
Oct 23, 2015 12:20 PM
Nick McCardle
Sep 10, 2015 08:36 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
SG91camaro
Sep 5, 2015 10:27 PM
