Upper door panel issues....
Old Oct 10, 2006 | 05:20 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I was curious what holds on the big black plastic piece that goes along the top of the door panel and sits up against the window. The piece is warped and the ends are starting to slightly curve upwards. You can push down on it and it will move about 1/2 and inch or so. I was just wondering what held these in place and if they are replaceable alone or if I will have to get all new door panels? The rest of the door panel is in excellent shape so if I can avoid replacing the whole panel, that's what I'd like to do.
Thanks in advance for any help or suggestions with this issue.
Old Oct 11, 2006 | 09:52 AM
Firebat's Avatar
there are clips on the back of that piece. If you can push it in that much, those clips are probably broken because someone else in the past had to take off the door panel. I wouldn't replace them unless that piece has a bunch of visible cracks. On one of my cars, its just like yours and it makes it really easy to take off the door panel, which is kind of nice when replacing a window motor or door lock solenoid.
Old Oct 11, 2006 | 10:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In the following link, you can see where two of the clips (four of them in all, IIRC) attach, one near the glass and near the middle of the pic, the other at the front of the door.
https://www.thirdgen.org/forums/atta...tion-guide.jpg
JamesC
Old Oct 11, 2006 | 03:32 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Yes, u can replace just the black plastic door trim on top of the panel. Very easy and cheap in a junk yard. $5- $15 depending on the yard. I can get em if ya cant find it. Let me know. Rcar7395@sbcglobal.net
Old Oct 12, 2006 | 10:20 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
where can you get those clips from? my black plastic pieces are in prestine shape but they rattle b/c they are secure to the door... any help?
Old Oct 13, 2006 | 05:29 AM
JamesC's Avatar
The clips are molded to the black plastic piece, IIRC. There are other reasons for rattles. Perhaps this link will assist if you haven't seen it:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
