Radio control steering wheel swap
Old Oct 26, 2006 | 05:53 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Thinking of swapping my 9k mile steering wheel with the radio controls to a like new three spoke wheel with GTA logo in the center I picked up for an arm and a leg on ebay yesterday.
I know the splines on the wheels will line right up but anyone that has done this......what about the horn setup ?
How different is it from one to the other.
Also what about the wiring for the radio controls, I don't want to cut them off. Can they just be tucked away in there ?
Yes the original like new operating perfectly radio controls and steering wheel will probably be sold, any ideas what it would be worth ?
Old Oct 27, 2006 | 06:03 PM
Jetmeck's Avatar
Surely someone has done this swap ?
Old Oct 27, 2006 | 07:35 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
the horn should just connect the same as the rest of the steering wheels. a small contact with a spring and plast retaining collar into the column.
Old Oct 27, 2006 | 07:36 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I did the swap but I used a 01 camaro steering wheel. I had to get a ABS coil out of a car with it. the coil had two wiring ends one for the airbag, and one for the controls. hope this helps
Old Oct 27, 2006 | 10:31 PM
Jetmeck's Avatar
Yes but since the two horn buttons are in slightly different
locations I hope they hook up to the horn the same ?
Any ideas ?
Old Oct 28, 2006 | 05:01 PM
johnnyboy's Avatar
i went from an '89 steering wheel with the 2 horn buttons on the outside, like the 91-92 steering wheels, to a steering wheel from an '87 with the 3 spokes and the center horn button, they both connect the same way.
Old Oct 28, 2006 | 08:48 PM
Jetmeck's Avatar
thank you
Jorlain
Aug 24, 2022 05:11 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
