Dashboard Pad Question
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Are all thirdgen dashboard pads interchangeable?
Car: 1969 grand prix
Engine: 389+.030, comp cam, Edl manifold, Hooker , Edl carb, 1.65 Roller rockers, 3 in exhaust
Transmission: TH-400
Axle/Gears: 3.23 not that bad with enough torque
Im no expert but Im pretty sure camaro pads gotta stay with camaros, and fire bird trans-am pads interchangeable on 82- 85 86-92 pontiac f- body. Like i said could be wrong but that's what i was told.
Car: 1987 Z28
Transmission: auto
Axle/Gears: ?
I don't think they are interchangable but you can get a dash pad cover on Ebay or from A-1 that installs over top and looks great. Pretty easy to install and mine was a perfect fit. I paid about $95 plus shipping and got it in a few days. You do have to remove the existing dash pad which is very easy. Good luck
I know this first hand.The dash pad from an 88 camaro does not fit ,as a direct bolt swap, the dash of my 90 camaro.Now if ya did the whold dash then it would fit.But pad for pad no.And I have the x-tra pads ta back that up.
I had one, they do look good and they are easy to install BUT they also warp very easily if you leave your car outside in the sun.
Vintageracer
Aug 11, 2015 08:13 PM
