DAM an BLAST im british!
Old Jan 10, 2007 | 04:19 PM
M@88iroc's Avatar
Car: 1988 Camaro IROC Z28
Engine: 5 Litre V8
Torques head bolts in the steerin colomb have come lose and now I hav an annoying wiggle that is waiting to help me crash,lol! How in the hell do I get in there to do them up. Does anyone have a step by step guide on how to do this?
M@
Old Jan 10, 2007 | 05:03 PM
Gramps's Avatar
Car: 87 Camaro IROC
did they sell camaros over there or did you have to get it shipped over there?
PS: its negative ground wiring so be carefull
Old Jan 10, 2007 | 05:21 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
May I direct you to Vader's post in a similar thread. I tried to post the link but failed miserably, so I'm pasting the original content and risking Vader sueing me. I promise I didn't write it!
"Your car will be a little easier if there is no VATS wiring and SIR coil/wiring/gas bag. If you have VATS, there are only two more wires that need to be handled. With SIR, you have an entire additional procedure to remove and reassemble the system. You really should have a service manual in hand for that procedure.
Start by centering the steering wheel, so that the wheel can be replaced in exactly the same position on the shaft easily. The steering shaft is both marked and keyed, but centering the wheel makes the job easier to "eyeball", and keeps the turn signal cancelling cam out of the way in later steps.
Next, remove the hazard flasher **** on the lower right side of the steering column. There should be a small (#0) Phillips screw holding the **** in place. Find the release clip or bolts for the horn sounder pad and remove it. As the pad is removed from the wheel, unplug the horn wire from the connector on the pad. Remove the horn sounder wire and the insulator that guides the wire through the steering wheel. The insulating sleeve needs to be pushed inward slightly, twisted ¼ turn anticlockwise, and removed from the wheel. There is a light spring in the sleeve, so make sure all the parts are removed together.
Remove the safety clip from the steering shaft, then remove the nut. You might have to have an assistant help hold the wheel while you turn the nut loose. Install the bolts from your steering wheel puller into the tapped holes in the wheel, and turn the puller screw to release the wheel from the steering shaft.
Depress the notched wheel locking plate and remove the locking ring located at the center of the plate. There is a special tool for holding the wheel locking plate while the snap ring is removed, and it will be worth the $15.00 you'll pay for it. It can be done without the tool, but it is an exercise in frustration unless you are an octopus. I've done it several times using the "Armstrong" method, now I have the tool and use the "Brainstrong" method instead.
When the wheel locking plate is removed, you can look at the left lower side of the turn signal switch and see a pan head Phillips screw that hold the turn signal lever in place. Remove this screw and plate, then move the lever out of the way. There are three more pan head screws that hold the turn signal/hazard lamp switch to the upper column. Remove those and lift the turn signal switch out of the way. You may need to feed some extra wire from under the column to allow the switch to clear the steering shaft and move out of the way completely.
Once the turn signal/hazard switch base is out of the way, you should see another pan head screw on the upper right side of the column. This screw holds the lock cylinder in place. Before you remove the lock cylinder, make sure you hold the plastic/metal foil contact assembly in place so you don't lose it down the column when the lock is removed. This switch assembly is what actuates the key warning buzzer/chime. If you have VATS, there should be an additional pair of wires to umplug and feed down along the column.
Remove the column tilt release lever by unscrewing it. Set it nearby since you will need to reinstall it after the upper bowl trim jacket is removed. Remove the turn signal / multifunction lever shaft by carefully pulling it out of the switch. Unplug the cruise control wire harness (if equipped). Remove the remaining upper bowl trim screws and lift the upper bowl off the column. Find the column tilt release lever and thread it back in hand tight for now.
Remove the upper steering shaft bearing nut and retainer clip. Remove the upper bearing set. Remove the actuator rod link from the rack/sector that operates with the lock cylinder. Disconnect the link from the clip in the lower column.
Remove the balance spring cap with a #2 or larger Phillips driver or larger square drive. This will allow the upper column fall to the lowest tilt position.
Remove the pivot pins from either side of the upper column using an 8-32 screw and nuts as a puller. Assemble the parts as shown, fully bottoming the screw by hand (to get the maximum thread bearing strength), then back it off a turn or two in case the bolt snaps later. Once the screw thrread is set, run the nut down with a wrench to jack the pivot pin out of the column die casting. It the screw snaps, there should be adequate material to back it out by hand (which is why you didn't bottom it out to begin with). Usually, the pin will pull easily once it starts moving and deforms the stakes that were retaining it.
Once the pins are removed, operate the column tilt release lever and remove the upper column half. Note the routing of the ignition switch linkage rod(s) when you remove the upper column half. Tilt the upper stub shaft and universal joint to allow the joint to be separated.
At this point, you should be viewing the top of the lower column half and four Torx cap screws. Remove these screws one at a time, clean the threads, and apply a light coating of LocTite 242 or an equivalent medium strength removable thread locker. Tighten the bolts by hand until all four are reinstalled. Torque these bolts to 180 in/lb.
Reassemble the upper column half in reverse order. Take time to clean and grease all the moving parts so you can have another ten years of reliable operation. Every moving part, including the turn signal switch and cancelling cam, should be cleaned and lubricated with white lithium grease.
When assembly is complete, torque the steering wheel nut to 35 ft/lb. There are already enough loose nuts behind steering wheels on our roadways....
There is a possibility that some of the pan head screws are Torx instead of Phillips. I believe this was more common on 1985 and later cars, but your's may have them as well.
There is also a very remote possibility that your car has an inflatable restraint, in which case you'll need to disconnect the battery and insulate all connections before you start. You should also have a service manual to detail the proper procedure for removing and re-centering the triggering coil and pickup for the SIR. You don't want to have that done incorrectly. Come to think of it, a manual is a good idea, anyway."
__________________
No Gramps, the third gen was never sold here. The later 4th gens were for a short while along with the Blazer, but they never caught on so they were pulled. Makes our cars more interesting!
Negative ground? So that's why my 12v gramophone keeps blowing fuses....
Old Jan 10, 2007 | 05:37 PM
M@88iroc's Avatar
Engine: 5 Litre V8
Yeh gramps for your info buddy we hav these really shity cars over here called rovers, bmws, fords for the e.u market (mondeo, focus etc) renaults, citreons an so on. They mostly dont go over 2ltr in line 4's and they are all crap! We have crap insurance polocies here, road tax, MOTs. I hate our car market hense why I have an 88 iroc Z28, LUSH! It was only in the states for a couple of years then shipped over here, bought it when i was 19 and had her now 3 years. Oh an I cant get the link to work?
Old Jan 10, 2007 | 05:39 PM
si_camaro's Avatar
Car: 85 Z28
I replaced the link...sorry it failed.
Old Jan 10, 2007 | 05:40 PM
M@88iroc's Avatar
Engine: 5 Litre V8
Yeh just got it throught cheers bud, life saver!
Just had a reda through of what you put up and I need to go further than that. Theres 2 more torx bolts that have come lose, only little about size 10 in behind all of that. Any ideas there?
Old Jan 10, 2007 | 06:24 PM
Gramps's Avatar
Car: 87 Camaro IROC
right on ma88. i didnt mean to raz you about you bein a brit and all. enjoy that maro. try to get a TVR tuscan bodykit for it
Old Jan 11, 2007 | 12:00 PM
M@88iroc's Avatar
Engine: 5 Litre V8
No worries dude, its ok to rip the **** out of ur cars, there crap! But I waudnt put TVR kit on my camaro, it wud ruin her?
M@
Old Jan 11, 2007 | 02:02 PM
Gramps's Avatar
Car: 87 Camaro IROC
M@
mayb u should just buy the TVR as your daily driver, then you can fix up your camaro, they better ne ways
Old Jan 13, 2007 | 10:12 AM
M@88iroc's Avatar
Engine: 5 Litre V8
Got the to bolts done up but en route i managed to damage the white plastice thingy that feeds the horn and hazard switch. It has 10 wire coming out of it, any ideas what this is called guys? And then I just hav to get one in england then, great fun!
M@
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
tommy z-28
Oct 6, 2015 10:58 PM
steimel94
Sep 23, 2015 12:48 AM
