Heater Control Problems
Old Jan 23, 2007 | 05:36 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
So, I have a brand new control unit. But my vents will not work, air only blows out of the defroster. I know this is the default position due to a faliure somewhere in vacuum? I checked under the hood and the vacuum line going into the harness is properly attached. But, on the back of the control unit itself, the diaphram with all the tubes going to it is leaking around the middle section. Could this be my problem? If so, where can I get another diaphram with tubes like that, that does not leak??
Old Jan 23, 2007 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. I replaced the switch itself under those circumstances and all works well. If the unit is brand new (switch and all), I'd fuss a bit.
JamesC
Old Jan 23, 2007 | 07:07 PM
techno101's Avatar
Car: 1989 Camaro RS
Well only the dash inserted Control unit itself is new, not the vacuum tubes behind. Is there a way to splice on a new diaphram with leads? Where could I get one??
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
