Manual and Power Windows
Old Mar 5, 2007 | 04:34 PM
Sunny's Avatar
Car: 1986 Z28 Camaro
Hey guy's, I wondered if it's possible to convert a power windowed car to manual. My car's doors are manual, but I am getting replacement doors.. however they are power windows.. and I dont really want to run all the wires etc.. can this be done? All the searches I found were manual to power, not the otherway around
Old Mar 5, 2007 | 06:54 PM
BIG_J_420's Avatar
Car: 82 T/A
Engine: stock 350
well depending on how you read it, it could be power to manual. I'm a little dyslexic, so it works for me.
Old Mar 5, 2007 | 09:50 PM
69-er's Avatar
If your old manual regulators are still good, it's bolt-in swap. You will find that the two regulators use different holes in the door structure, (which are pre-drilled). That's the only difference between the two systems.
If you don't have any 1/4" rivets, you might want to weld some 1/4-20 nuts on the holes of the regulators so you can use 1/2" long bolts to mount them. It's next to impossible to get your fingers in position to hold the nuts in place to insert the bolts. I did that on my conversion and it worked perfectly. Cut out the holes in the door panels for the cranks and you are done.
Larry
Old Mar 5, 2007 | 10:31 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
But I did the manual to power and trust me it was well worth it. Cranking sucks.
Old Mar 7, 2007 | 01:05 PM
Sunny's Avatar
Well the doors I'm getting HAVE power motors..they just dont work.. so I dont really want to spend MORE money on it..
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
