door panel question
Old Mar 20, 2007 | 09:26 PM
jt2007's Avatar
door panel question
I know that most parts on the 82-92 camaros can be swapped around, but i wanted to make sure that these would fit before i buy them. I have a 83 z28 w electric windows, and i wanted to know if door panels from a 89 iroc z would fit. Thanks
Old Mar 20, 2007 | 09:43 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: door panel question
You should be able to swap them without a problem as long as the IROC had power windows.And then the only problem would be covering the window crank holes.The '82 Camaro's actually had a cover for the holes but in '83 they started using a solid panel for power window cars.
And welcome to TGO if someone already hasn't.
Old Mar 20, 2007 | 10:09 PM
jt2007's Avatar
thanks. I just wanted to make sure that they would fit before i spend the money on them. Also, any ideas how to replace headliner other than just buyin a new one? is there any custom fabrication ideas w sheet metal or diamand plated sheet metal that you know of?
Old Mar 20, 2007 | 10:17 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I hope not
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
