window removal????
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
window removal????
between trying to drill out rivets and taking out a ton of 10mm bolts. i'm left with the window still in my doors because of the rollers in the window tracks.
Who has done this successfully and is it possible to get new rivets or use nuts n bolts etc.... but mainly how do you remove the window?
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: window removal????
once the rivets were drilled out the glass came right out,but those rivets aaaarrgh
Axle/Gears: no idea
i had trouble gettign the window out because of the rollers in the window track. i have no idea how someone can remove and install a door window with any ease.
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
