will these grant parts fit on my 91?
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
Hey I'm about to order a new steering wheel and adaptor.
The steering wheel I chose is a Grant Racing Performance Series wheel. http://www.jegs.com/webapp/wcs/store...0002_313708_-1
And the adaptor is where I'm stuck. Will this one work?
http://www.jegs.com/grant/grant_install_guide.html
So will this adaptorr fit my 91 camaro? and will that adaptor accept the steerign wheel i chose? thanx in advance.
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
Re: will these grant parts fit on my 91?
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I've successfully installed a Grant steering wheel in my 87 TA. I bought the wheel and the hub at an autoparts store. I've seen them in all the major chains. You should probably check that out before you order it...
As I recall, as far as the hub...I think its a GM thing like "GM 82-02" or something like that. Nothing F-body specific...
Car: 1987 Trans Am
Actually, here you go..., this is what I got, but I paid $40+ for it at the store...you can use the p/n if you don't go with ebay...
http://cgi.ebay.com/ebaymotors/New-G...spagenameZWDVW
or http://www.jegs.com/webapp/wcs/store...10002_49368_-1
or http://store.summitracing.com/partde...5&autoview=sku
I'd call Summit and ask them in particular if there is one specifically for 1991 Camaro...
