Power window failure
Old May 15, 2007 | 03:45 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Alright, so today I was rolling down my drivers side window and about 2/3 of the way down it just stopped. I'm guessing that it is the switch as is wasn't in all that great of shape. The plastic bezel that surrounded the switch itself and keeps it from falling through the console was half missing (cracked in half). However, that is just my guess. Maybe it could be the window regulator or a loose wire, etc.
I really don't know what to look for, or how to repair anything that has to do with power windows. So basically my main question would be: "What is wrong with my power window?" and "how do I fix it?"
I need help ASAP. My window is stuck more than halfway down and it's has to sit outside for the night. I would really like to not have to do it again.
Old May 15, 2007 | 01:52 PM
articmink's Avatar
Car: 1987 Iroc Z-28 L98
Engine: 5.7 350 TPI
Transmission: A4
Re: Power window failure
Did you check your fuses? That would be the easy fix Could be several things, as you suggested the switch, the motor or loose wire.
Old May 15, 2007 | 03:56 PM
DBLTKE's Avatar
Engine: LB9, LB9
is there a seperate fuse for the driver and pass. window? My passenger window will still roll up and down just fine.
Old May 15, 2007 | 04:57 PM
articmink's Avatar
Engine: 5.7 350 TPI
Transmission: A4
no both work on the same fuse so its your switch, motor or loose wire
Old May 15, 2007 | 06:38 PM
BHicks's Avatar
Car: 1986 Monte Carlo SS Aerocoupe
Engine: L69 305 H.O.
Transmission: 200-4R
unplug the pass side switch and plug into the driver side and see if it rolls up
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
