4th gen wheel + steering wheel controls
Old Jun 26, 2007 | 09:28 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
I want to add steering wheel controls to my 91 TA. I want a steering wheel from a 93-94 TA with the radio controls. I have a cd player that will work with these controls. I have read a few topics about the wheel bolting up, but nothing about the airbag or radio controls. I have an entire column and radio harness from a 94 Bonneville, it's the same year but the color is too light. I am looking for one from a Firebird. I have a few questions:
Does this airbag have the same connector as the 90-92?
Will this airbag fit a 90-92 wheel?
Is it feasible to run the wires through the third gen column?
The first pic os the wheel I want, the 2nd shows the cd player in my car now.
Attached Thumbnails 4th gen wheel + steering wheel controls-1782882_15.jpg   4th gen wheel + steering wheel controls-022_05a.jpg
Old Jun 30, 2007 | 10:55 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: 4th gen wheel + steering wheel controls
I have a similar cd player to yours. I plugged it into the factory harness with no hassles. But the steering wheel control plug was totally different. If you ran all the wires from a newer car it should work. Putting the wires down the steering colum should not be an issue at all. That first steering wheel I have never seen before in a 4thgen bird.
Old Jan 26, 2008 | 03:40 PM
1991TAGTA's Avatar
Car: currently looking for a 1991 TA GTA
Hey Did you ever try putting the steering wheel controls in? I have a 91 GTA and Im also wondering if it will fit?
Old Jan 28, 2008 | 06:06 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
I have the parts but haven't attempted the install. I have a wheel from a 94 Bonneville that is the same one as the bird one above. The wheel is found in 93-94 Firebirds and 92-95 Bonnevilles. I also have a steering column from a 98 TA. I already have a 4th gen cd player.
I decided that it would be easier to use a column that is already wired for steering wheel controls rather than mess with the clockspring. There are four wires that come off the steering wheel controls. Two go to the radio and two are for illumination. The new column came with a key so I will bypass vats. The airbag connector may be different, I'm not sure.
Old Jun 4, 2008 | 11:12 PM
Savannah Dan's Avatar
Did the 98 steering column fit OK?
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
