steering wheel swap
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
steering wheel swap
my 89's foam on the top is very weak and flexes was curious if it is possable to use a grand prix steering wheel theres so many at the bone yard i could easially pull on off i cant seem to find any firebirds at the yard currently
possable?
possable?
Engine: LS1, LB9, L03
Re: steering wheel swap
Pretty much any GM steering wheel with that style steering column would work. So to answer your question, yes, that will probably work.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Also, if your bird has the airbag, you should be able to swap in a 4th gen bird wheel with the airbag - I did this in my Camaro - the only thing different is the airbag connector - in the 4th gen's they used a smaller connector, so get the airbag connector from the donor car, or cut the connector off your airbag and splice it in the new bag.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes any GM one is the same shaft spline and diameter, from at least the 60s through 90s, trucks vans cars caddy pontiac olds buick gmc all of them
ive removed, installed, swapped billions over the years
good luck
good luck
backtothe80s
Sep 5, 2015 12:39 AM
