Window question...... need help
Old Jul 22, 2007 | 02:01 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I am swaping the power doors in my camaro. the problem is my new door has the window rolled down and there is currently no motor or wirirng harness in the door. so i have no power to roll the winodw up. is there any way i can get the window up with no power? is there any way to get it up at all?
thanks
Colt
Old Jul 22, 2007 | 02:20 PM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
Re: Window question...... need help
The only thing I can think of is manually going in and turning the gears by hand. But I am a little confused, is the window supposed to be manual or power. Either way, without out the handcrank or motor there is not much besides what I can up with, but if someone else has a better idea lets hear it cause ive seen enough threads that ask help.
Old Jul 22, 2007 | 03:28 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
the window is power, it has the motor connected to gear and armature and is still rivited in the window. i need to know if there is a way to get the window up with the motor connected to the armature and door without any power to it
Old Jul 22, 2007 | 05:12 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Did the car have power windows to start with?If so then just connect the motor harness plug(harness doesn't have to be in the door to do it).If not then apply power to the connector on the motor.Use a set of jumper cables from the battery and then smaller,12ga for example,wire to connect.It may take 2 tries to get polarity correct for the motor to move the window up.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
