Steering Column
Old Aug 7, 2007 | 08:20 PM
dustpusher's Avatar
Car: 88 IROC-Z
Steering Column
Hi I have a problem with my column.The center shaft that the wheel goes on is loose.It isnt the normal tilt being loose.I have searched but I couldnt find anything to fix it.Is there a place that rebuilds columns in Indy?Or does anyone have any tips to fix this without taking it somewhere?Also Im sorry if this is in the wrong spot. Thanks Dave
Old Aug 7, 2007 | 08:44 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Re: Steering Column
https://www.thirdgen.org/steeringcolumn
I think it says dont use lock tite, but i did, and mine has been good for like 3 years now. Make sure you take care of it quick. It'll just keep getting worse and worse, and i dont know why but with mine eventually stuff started not working (high beams, turn signals etc.) Go out and buy the right tools, it'll save you a headache and its well worth the money even if you'll never use them again.
Old Aug 7, 2007 | 09:17 PM
dustpusher's Avatar
Car: 88 IROC-Z
Re: Steering Column
I saw that but my problem is different.The shaft that the wheel goes on is loose.I replaced the lock cylinder and I pulled the shaft loose and cant get it back in the right spot.Thanks for the reply.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
