gauge swaps
Old Sep 1, 2007 | 10:53 PM
shaolink9's Avatar
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
gauge swaps
so..i got a 86 z28 i wana put 90-92 gauges in it can i just put them in like i did the 1988 pod?? is the speedo cable gonna hook up?....
Old Sep 2, 2007 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: gauge swaps
82-89 speedo heads are mechanical, 90-92 electric. Moreover, without major modification, the 90-92 cluster won't fit your 86.
JamesC
Old Sep 2, 2007 | 09:42 AM
cdoyle's Avatar
Re: gauge swaps
Take a look at this thread
https://www.thirdgen.org/forums/body...swap-92-a.html
Overall it's not really that hard of a project to do.
Chris.
Old Sep 2, 2007 | 06:07 PM
shaolink9's Avatar
Transmission: th350
Re: gauge swaps
so now im thinkin about reverse glow gauges only issue is the gauges pod i have camm out og a v6 or l4 i guess. So where the tach is on most v8 cars is a huge gas gauge and all the little gauges are dumby lights. YAll think i can find reverse glows for this style cluster
Old Sep 2, 2007 | 06:27 PM
cdoyle's Avatar
Re: gauge swaps
It's easy to upgrade that cluster to the tach version.
Before I changed to the 91/92 style, my car orignally had the cluster you had. With the big gas gauge and dummy lights.
I just went to a junk yard, and found the better cluster with the tach etc.
I first swapped out the water and oil sending units. Then I just plugged the cluster in, and everything worked.
I doubt you'll find reverse glow, in the dummy lights gauges.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
