Pillar pod gauge choices????Please help
Old Oct 22, 2007 | 09:01 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
I'm trying to decide which type of gauge would look better
I have a Black TransAm GTA with grey and black interior
Which ones????
You can find the gauge types at autometer.com
Budget alittle tight
Please help!?!?!
Thanks in advanced
Old Oct 23, 2007 | 09:49 PM
Engine: 350/350/LS1
Re: Pillar pod gauge choices????Please help
Any advice/help
Old Oct 24, 2007 | 12:20 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
well my man....if it helps i just bought the triple gauge pillar from autometer.
color: all black
i plan to fit it with a nitrous,airfuel and oil or volt gauge.
here it is....i won this sale.
http://cgi.ebay.com/ebaymotors/ws/eB...107914229&rd=1
i know the pillar is boxed up but its part # 12203......Trust me its a tight FIT....It looks VERY VERY GOOD installed.
the cons are:
1st...You must fit it FLUSH over the existing pillar....if you dont then you end up with lots of big holes in your existing pillar. But your a professional so no worries there.
2nd......after pillar is mounted up the dash pad seems like is doesnt want to go back in WITHOUT forcing IT. Which in my case led to a nice dash pad crack. My pad was old and dingy so i didnt get TOO mad.
last....its really not much room in between the existing pillar and the aftermarket pillar. You might end up sitting in your car for a couple hours just trying to wire up all 3 gauges. I advise you TRY to PRE wire everything you can then mount pillar.
peace
Old Oct 24, 2007 | 12:26 AM
1991ON20's's Avatar
NOW FOR THE GAUGES..........
MINE ARE ALL AUTOMETER WHITE FACE GAUGES that work fantastic....
i was alittle off the subject but i hope it starts a buzz for your thread.
Old Oct 24, 2007 | 02:08 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I think that the autometer carbon fiber series match the trans am interior best. You may need to keep saving if you are going to put a full set of electronic guages in.
What is it that you are wanting to monitor with the guages?
-Schultzy
Old Oct 24, 2007 | 03:24 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Do you want a double or triple gauge pod?
Old Oct 24, 2007 | 06:46 PM
Engine: 350/350/LS1
Triple with either Boost/vacuum, nitrous pressure(when I get the purge kit), trns temp, or oil tempurature gauges
thanks
Last edited by firebird896; Oct 24, 2007 at 06:47 PM. Reason: Automerged Doublepost
Bubbajones_ya
Jul 6, 2024 08:32 PM
Fronzizzle
Feb 9, 2017 09:31 AM
91 zeee
Interior Parts Wanted
Sep 24, 2015 03:09 PM
aharvel50
Sep 21, 2015 07:31 PM
86IROC112
Sep 11, 2015 04:04 PM
