steering column ?
Old Nov 1, 2007 | 11:06 AM
a-mean-89-iroc's Avatar
Car: 1989 IROC-Z
steering column ?
Ok guys ive heard different things about the steering columns on 82-89 fbodys. Ok what years will fit an 89 camaro. That i know of they will all fit but the wiring is different so which one has the same wiring that will fit my 89?
Old Nov 3, 2007 | 01:34 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: steering column ?
The ONLY column that will be an EXACT replacement will be from another 89 F-Body. The 89 set-up used the old style ( non air bag ) column - but was the only old-style column available WITH a VATS chip Key.
Old Nov 13, 2007 | 01:26 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
John's right. You also have to factor in tilt wheel, cruise control, and delay or non-delay wipers.
Old Nov 13, 2007 | 11:03 AM
BOTTLEDZ28's Avatar
Transmission: A4
i am in the same boat but with a 91? I have disabled my bag and remvoed it along with my VATS. so, basically, it the old school waybut my column seems to be getting looser and looser and now my high beams no longer work. Can I just swap out the entire worn out colun for a 4th gen one with lower milage and use on it? Do the 4th gen ones bolt right in?
Old Nov 13, 2007 | 06:06 PM
Axle/Gears: 3.27 BW
From what I just looked up, it seems that they will, you just need to use the thirdgen intermediate shaft (Between the end of your steering column and the steering box) and it should work fine.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
