for those intrested in dash swaps
about 7 or 8 months ago somebody was swaping out their dash for a 4th gen, and in that same post somebody was wanting a supra dash. well my boss had a Dodge Stealth that was pretty much junk and he let me have the dash and center councle out of it because the car was going to the scrap yard. so i polled it out and now its sitting in my garage guages and all + the computer but shhhh! you will see that on ebay in a few days hehe. but does anyone have any suggestions on how i should begin to mount this thing? i was thinking about taking the mounting bar that streaches the whole width of the car OUT and making a new one thats a lil higher and fabing up some of my own brakets.
Car: 1986 firebird trans am
Re: for those intrested in dash swaps
im still trying to figure out how to take the dash out of my camaro let alone put a new one in lol.
you wouldnt happen to know how to do that would you ? iv taken out every bolt i can find but there is somthing on the drivers side holding the dash hostage
have you taken all the guages and disconected all the vents and poked the connectors through the hole that attach to your guages? i just removed piece by piece and i have already done it twice. its also alot easier if you take the steering wheel off trust me.
the steering wheel isnt off but it is lowered. the guage cluster is out and all the wires and stuff i can see have been poked their their holes but there is somthing on the drivers side holding it wonder if ill find somthing i missed when i get back to working on it tommrow
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Having the column dropped and the center console removed is required to pull the housing out. There is a 10mm screw on bottom and 13mm nut on top on the Left and Right sides that hold the dash housing to the brackets. Then remove the 6 7mm screws along the top edge (after the dash pad is removed) and that's it.
If you have already removed the cluster than the speedo cable isn't the problem and you probably just missed a wire somewhere. Be sure that the electric power junction block wire(s) and the C100 firewall connector are completely disconnected as well as the body harness. After that it's just the options wiring that's holding you up. ( Cargo light, Rear defroster and so on )
Another piece of advise is to unscrew the hood release handle as many time there are wires that are run behind it and get cought up when trying to pull the housing out.
Good luck !
Good luck !
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
some cars are worse than others.
i couldnt get to mine to cut the tape, so i just yanked on it all pissed-off-like and it broke the clip.
i didnt care about the dash, but it ended up comming out in perfect shape.
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
