Steering Column?
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Steering Column?
Will an 89 steering column fit in my non vats 1988? Thanks
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Steering Column?
If you don't find out soon, I'll let you know as soon as I swap in a 90 column into my 88. It's been too cold these past couple of weeks for me to try installing it.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Engine: All 5.7's
Really? No vats issues? Groovy! Thanks!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I have installed a 87 column onto a 91 dash housing in the past. When I did this I had to swap the column connector for the wipers. The the correct wires were there - but there were in the wrong sequence on the plug.
I believe the 88 coulmn is the same as the 87 - but I don't know if the 89 is same as the 90-92. Just figured it's something you guys should watch out for before beginng your swap !
I did mine today since it was nice and warm.
The only thing I had to do was swap the connector, colors were the same and in the same order, just on a different style connector.
There was also a connector that wasn't used, but I am thinking it was the cruise control wires since my 88 had cruise and the 91 column doesn't.
sjorgens
Oct 1, 2015 07:54 PM
