Removing top rails from door panels
Old Apr 9, 2008 | 09:00 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Anyone know the easiest fastest way or tool to take the metal nuts off the backs of door panels without breaking the plastic studs? I do this alot and have many requests for good top rails, but I ruin so many door panels and top rail studs I hate to sell em anymore !
Let me know,
Thanks,
Ray
Old Apr 9, 2008 | 10:13 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Re: Removing top rails from door panels
they are a pain in the neck, for sure. I have had good luck with a pair of flat faced pliers, and unscrewing from the flange.
the other thing I have used is an odd bolt my brother found, it had a hole in the middle of the hex, a weirdo metric one, so we ground down the hex to fit into the nut, yet clear the plastic 'stud'. the trick is slowly unscrewing and going back and forth, loosen, tighten, slightly, loosen a little more, like a tap, almost.
thats about all I've found.
Old Apr 9, 2008 | 09:58 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I used a pair of needle nose pliers to unscrew mine. Be sure to grip the sides from the top, if you grip the nut from the side (like using a wrench) the plastic studs will break.....don't ask me how I know.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
