Steering Wheel Replacement
Old Apr 29, 2008 | 09:53 PM
rspitler's Avatar
I've got a '90 IROC that needs to have the steering wheel replaced. How do I replace the air-bag equipped wheel with an aftermarket? Is it possible? What about the air-bag wires?
Old Apr 29, 2008 | 10:22 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Steering Wheel Replacement
its doable, may fail for inspection if they realize it origionally had a bag however. As far as the bag you can solder in a resistor in series to keep the light out.
Old Apr 30, 2008 | 01:53 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
You just buy the hub for an 82-89 Camaro. Pull the SIR fuse. Then remove the stock steering wheel and then remove the the SIR coil (be careful not to break it if you ever plan on putting the stock wheel back on). Then follow the directions that came with the hub and steering wheel. If you want the airbag light to go away, pull the cluster out and remove the light bulb.
Old May 2, 2008 | 03:05 PM
rspitler's Avatar
Thanks for the info. Does anyone know what the resistor size needs to be?
Old May 2, 2008 | 03:13 PM
Car: 2012 Corvette
Engine: LS3
There's no need to use a resistor, I've never even heard that before. Just pull the fuse and bulb. That way you can easily re-enable the system later if you need to put the stock steering wheel back on.
Old May 2, 2008 | 04:24 PM
MNformula350's Avatar
That's all I did
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
