rivets in my headliner
Old May 7, 2008 | 10:24 PM
FormulaFranco's Avatar
Car: 1989 Firebird Formula 350
hey guys whats up.. summers almost here, and im just finishing up the bird, but one of the last things i need to do, is get the headliner switched out, i found a place that i can pick up and abs headliner(t-top) in the city but the thing is im not sure how to take off the original headliner, its not like the other posts say cuz in my dome light there are two rivits, so i cant just pop out the dome light and remove it like that, and the rivits were somehow put in from on top so i cant drill them out cuz there in the wrong postion, can anyone help me out?
Old May 7, 2008 | 10:30 PM
BriMc's Avatar
Re: rivets in my headliner
Is a dremel tool with a cut-off wheel or a pair of side cutters a possiblity? Once you cut the shell and pin the rivet should come free above.
Old May 7, 2008 | 10:32 PM
im not sure if that will work but its worth a shot i guess, no harm in trying
Old May 8, 2008 | 02:35 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
hello
nope they are not rivets!!!
in the dome light there are like 2 rivets but they are not!! they are like 2 nails out of the body to align the headliner in the center and they are like smallwashers with a star shape inside to keep the headliner and dome light in place!!
to remove you dont need any dremels but you only need a broken small screwdriver with the end of if it in a 90 degree angle so you can pull down those called like washers with starshape inside!!
good luck and i am sure because i took of mine 2 day!!
cya
Old May 8, 2008 | 03:57 PM
alrtie thanx for the advice guys u rock, as soon as i get her out of the shop im going to try and get it off. if i have any problems, ill be back with some questions, and even if i dont have problems, ill be back to tell u how it went, but if any1 else has ne suggestions than im still open to them, thanx guys
Old May 8, 2008 | 04:00 PM
Manovox's Avatar
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
its a pleasure to help!!
can you help me with an 89 camaro 2.8 v6 transmission mount t5 manual ??
may be its easy for you as i am from Malta in europe!! and i cannot find 1!!
thanks
Old May 8, 2008 | 04:05 PM
sorry boss, i have no idea on how to help you with this, but im sure if you start a thread, the guys on the forums would love to help.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
