Rear Plastics not fitting???
Old May 10, 2008 | 12:02 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Since i have had my camaro the rear plastics over the hatch motor and the spare tire didn't fit. well i bought some plastics out of a firebird. All of them fit except theses two. The to plastics stick up higher than the weather stripping and they dont sit in place... they almost like get in a bind. Almost like the need to be trimmed to get them to fit propperly. Is this because they are out of a firebird or camaro that is not the same year as mine? thanks alot. Please help me because its been a problem i have been trying to solve for a while. thanks alot. -Matt
Old May 11, 2008 | 01:54 AM
19CAMARO85's Avatar
Re: Rear Plastics not fitting???
anyone had this kinda of problem? I am out of ideas of whats going wrong. BUMP!
Old May 11, 2008 | 05:18 AM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Is the carpet interfering at the bottom?
While I've seen some not fit right because they were deformed by heat while not in the car, usually you can tell that's the problem.
Make sure the plastic push pins are going into there holes and not riding up over the anchors. That's what it sounds like is happening.
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
MORREALE5
Sep 13, 2015 09:16 PM
