91 firebird How do I remove the trim around the inner door handle?
Engine: LB9 305
Transmission: AT
I am trying to remove the door panel. It is loose except the black plastic trim, around the inner door handle. I removed the "firebird" emblum and the screw under the emblem.
In the center of the inner door handle TRIM, is a 1/2" diameter button or cover. I suspect there is a screw under it? I can't get the "cover" off.
This is NOT the same as the older F bodies, with the real and fake allen screws. Thanks
Engine: LB9 305
Transmission: AT
Re: 91 firebird How do I remove the trim around the inner door handle?
Nevermind, I drilled a pinhole in the button, removed it and the screw underneath.
Now I fighting the panel, trying to get it up, off the door, at the top!
Roll the window down
Pull out all of the christmas-tree clips so the panel is floppy
Pinch the top rear of the panel with your hands
You will feel the little clip release
Repeat for the remaining clips and the panel will release
*Note* You must keep a minor upward force on the panel or the clips will snap back in
Be gentle and it most likely wont break
The upper plastic pieces are quite expensive to replace
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
