How to remove HVAC bezel (face plate) 92 Camaro
Old May 23, 2008 | 04:42 PM
mikeiaz's Avatar
I have spent a lot of time trying to find this using the search function but no luck - I am sure this has already been answered but darned if I can find it.
I need to get into my HVAC controls and would appreciate tips on how to remove the upper console bezel/face plate so I don't screw it up. Is there a 4th screw in the upper left corner hiding behing the corner of the guage surround? Do I need to loosen/remove the shifter-ashtray plate first? (mine is AT).
THANKS IN ADVANCE
MIKE
Old May 23, 2008 | 04:58 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: How to remove HVAC bezel (face plate) 92 Camaro
It does make things easier to remove the ashtray/shifter plate first. There is a groove in the lower edge of the radio/HVAC bezel that fits int the shifter plate. The screw on the upper left is a fake to make the trim look nice, but there is a hook under it that slides in to the left, so once all the screws are out, slide a little to the right and it should come off.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
3rdgenparts
Aug 8, 2015 07:09 PM
