Real Dumb Question!!
Old May 26, 2008 | 09:25 AM
9secz28's Avatar
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
Got kind of a dumb question. I have the motor and everything stripped out of my car and I can't get the rear hatch to open without any power in the car! How do I open the rear motorized hatch without any power in the car?
Old May 26, 2008 | 09:37 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Real Dumb Question!!
The key should work. Did you shave the back key off or something?
Old May 26, 2008 | 09:52 AM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
flip the license plate down.. there is a lock under it.. your key should work.
Old May 26, 2008 | 10:02 AM
Firebat's Avatar
You can get it to open from inside the car also. I think you remove the rear cargo light by the hatch(not the roof dome light), you can get a flathead screwdriver in there and manually open the hatch. Or if you're interior plastics are gone, you can get to it.
Old May 26, 2008 | 10:15 AM
9secz28's Avatar
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
My 91 had the key under the liscence plate put I looked there and this car doesn't seem to have it. Not sure if it was shaved off or what the story is. Just bought the car a month ago and have been ripping it apart to do a complete restoration on it and I came across this problem. Thanks for all your help as always! i'll have to try a little harder to get it open when I get home from work.
billybob6110
Sep 24, 2016 09:50 AM
inferno15
Aug 29, 2015 01:48 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
