Steering wheel won't come off
Old Jun 3, 2008 | 06:40 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Anyone ever have a steering wheel that just won't come off? Yesterday I tried to take mine off, and gave up after 2 hours of trying. I actually bent the steering wheel puller even. I also tried the "pull on the wheel while you hit the shaft with a hammer" method, to no avail. I've taken several off other cars, with nowhere near this much trouble, I even pulled one from a junkyard car once by just pulling and wiggling on it. I have a spare GTA column in the shop, but I don't remember if it's in good shape or not - I'm gonna go grab it tonight. Are there any tricks for getting off a stubborn wheel? It's in bad shape, so I don't mind trashing it in the process.
Old Jun 3, 2008 | 06:47 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Steering wheel won't come off
i would try spraying some PB blaster on there then later trying again.
Old Jun 3, 2008 | 07:44 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Just going to throw this out there, but did you remove the nut and safety clip? Sometimes I get in a rush, especially with easy stuff that I have done a zillion times and forget the basics....There's nothing except maybe rust that can be holding it on.
Old Jun 3, 2008 | 10:19 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
map gas tourch. mine was a bitch to. i used the tourch use the tourch before you spray the pb blaster.. heres a trick get the shaft cherry red then hit it with the pb blaster( eye protection plz) capillary action will pull the pb blaster right down the threads. we use this method on big city boilers at work
Old Jun 4, 2008 | 12:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, I got it off tonight. I bought a better puller, and some PB penetrating oil, let the oil soak for a few minutes, and it came right off. I'm not sure which did the trick, but it was easy this time. Thanks for the replies!
backtothe80s
Sep 5, 2015 12:39 AM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
