Was heading to work
Old Jun 4, 2008 | 10:12 AM
U4GN_Blackmagic's Avatar
Car: 84 Firebird
Transmission: turbo 350
Was heading to work
Well I went to work and was gonna turn my car off after I parked it when the key lock tumbler didn't work lol .. It was stuck and wouldn't move at all so I had to break it to turn it off and hotwire it to get it home .. It sucked but its funny a 11 dollar part can give you such a prob. Just thought I would share my funny morning with you guys ..
Old Jun 4, 2008 | 07:01 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Was heading to work
wow that kinda sucks. glad it didn't make you mad though. Like if too short to be mad about everything!
Old Jun 4, 2008 | 07:05 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
same thing happened to me a while back but i have vats so that cheap part for you truned out to be about 100 or so for me. i hate vats.
Old Jun 4, 2008 | 08:15 PM
Car: 84 Firebird
yea I bet I am just getting back from the parts store it was 11.00 bucks .. so now I got to find a diagram or something to show me how to take this out and put it back in.. Haven't had to do this before ..
Old Jun 5, 2008 | 12:05 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I don't have a problem turning the key forward to start it or backwards to take the key out, but the key never wants to go all the way back so the auxiliary(I think thats what its called) power turns on. Is this a sign that tumbler is going bad? Also, what is vats?
Sorry for my ignorance,
Mike
Old Jun 5, 2008 | 12:45 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Mike
VATS is the security system built into the 90 and later Camaros. It features a chip in the key that makes a regular five dollar key into a $50 or more experience if you lose your keys.
Old Jun 5, 2008 | 01:15 AM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Mike
Mine wouldn't turn back into the accessory position either until I tore my steering column apart and shot some white lithium grease on everything....works like a charm now...
The VATS system....basically, there's a resistor on the key...when you insert the key, there are contacts in the ignition which check the resistance...if the resistance isn't correct, then the security system won't turn off and you won't be able to start the car.
While I had my steering column apart, I also bypassed the VATS system just so that it couldn't give me any problems in the future....it's really easy to do....I simply just cut the two wires right next to the tumbler....pulled 'em down and out of the steering column...checked the resistance of the resistor in my key (9.4k ohms)...went and got a 10k resistor (which actually read 9.7k)...soldered it inbetween the wires...put electrical tape around it...wound up the wire all nice and neat and tied it up and out of the way....it's great not having to worry about it.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
