Aftermarket dash pad
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I noticed classic industries now has an aftermarket dash pad for Camaros. Anyone ever tried it or seen it?
http://www.parts123.com/index/google...C-12511119.htm
DASH PAD 1982-1992
Black Original GM Paint as Required
Details
Part# 12511119 Pkg EACH
Price 349.95
DASH PAD 1982-1992
Details
Price 349.95
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Re: Aftermarket dash pad
its gm original. so i assume itll be fine. but for 400 bucks after shipping
!!!!! ill just live with my hair line crack
!!!!! ill just live with my hair line crack Re: Aftermarket dash pad
That's not "too" bad......I paid that much for my 82 Corvette dash pad and it has a lot more curves in it than the third gen pad. (means it takes more to make)
If that pad is anything like the one in my vette it'll fit horribly...
Thankfully the market still has a ton of nice used pads that still look great
On a side note....it says "paint to match"....I though all the third gen dash pads came in black on our cars
Car: 88 IROC
Its not a GM orignal. It's listed as OER, not OEM. OER means Orginal Equipment reproduction (aka a fancy way to say aftermarket). But is a bit pricey and I am pretty sure it does just come in standard black but you can paint if you want.
I doing a 100 point restore on my car. So I may consider it. I am having a hard time finding one that is not cracked here in AZ. The sun is brutal on the interiors. But sounds like the vette ones were pretty bad quality.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I called "Just Dashes" (www.justdashes.com)... They want $500 or so to actually redo your dash... But I hear they do excellent work...
Other thing, I thought dashpads changed from 84 to 85, I'm pretty sure they did for Firebirds, how about Camaro's???
Raf
Raf
Car: 88 IROC
Raf
Raf
I don't think they ever changed the dash pad on the Camaros. If they did it would be the 90 to 92 model years when they updated the interior, but I think they still keep the same dash pad.
